Ok, so as of Tuesday last week I've now got an idle issue and despite searching the forums I'm not quite sure the cause, so am hoping for some imput and ideas.
The Problem
What will happen is when I start the car (typically from cold) it will be ok for a minute or so, then anytime I'm in neutral the idle will be hunting, going down as low as 200 and up to around 800, like a pendulum. If I'm driving with higher revs when I get into neutral the drop and swing of revs will be harder and it will be on the verge of stalling.
It will eventually close the range of revs until it gets to the 800 idle the car is set at. The longer I drive it the less it will hunt until eventually, say after 10 mins of city driving it will idle normally. Also, using AC or brakes doesn't appear to affect this issue.
Some specs
R33 GTST bigger turbo, 740cc injector, FMIC, exhaust, Z32 AFM, Walbro fuel pump and a Tune in December.
All of these parts were bought and fitted new within the last year.
In addition here are some common things to check regarding a poor idle that I've already considered.
- AFM poor soldering (unlikely as is a new unit)
- Vacuum/ IC piping - checked and were ok, and many have been replaced with silicon anyway
- ACC clean - done
- Fuel filter - replaced
- Plugs - 1 month old
- O2 sensor - 9 months old
- Coil packs - original, but are in good condition (and I don't think this issue relates to them anyway)
- Water temp sensor - original
What I think It might be
Seeing as my problem seems to be the regulation of air while the throttle body is closed, I'm thinking it could well be part of the Idle Air Control Valve system that is causing this. From what I can see there are two main parts, the popular one that people seem to talk about being the ACC valve. While I have cleaned the IAA unit (That's the wad hanging off the inlet manifold that contains the ACC, the cylinder hanging off the side) has anyone heard of that ACC unit being faulty or failing? Could it be a case of swapping this out?
The other suspicion I have is that it might have to do with the Air Regulator, which is the unit located below the IAA unit and connected by a vacuum hose (which continues back into the inlet plenum). According to the manual the air regulator is fully open below 20 degrees, half closed above 20 degrees and fully closed at above 60 degrees of water temp. This would seem to correspond to the times in operation that I will typically have this problem. Has anyone had this unit fail at all, or could it be cleaned back to good health?
And aside from this, is there anything that I may have missed which fits the symptoms of my idle problem?
Ok, thanks all
https://www.sau.com.au/forums/topic/463750-idle-problem-from-cold-ideas/
assuming you are talking about a R33 S2 since you didnt actually say;
try cleaning the cold start valve as well
http://www.sau.com.au/forums/topic/410701-rb25-cold-start-valve-clean/
oh and since you had a 'tune' i guess that means you're not using the stock ecu.....?
might help if you say what ecu you have too, its a pretty major mod =)
Good work on putting up some useful info to get a reasonable answer though, hope you can sort it soon and let us know what it was.
  • Like 1
The tuner did say that although he put in numbers for cold start he said should be fine (it was a heatwave at the time and he wasn't able to do a cold start), that I could contact him in colder months if there was an issue. That said, I don't think this is it as it happened suddenly last week and has persisted, which suggests its something failing.
And thanks for the link Sklyn, that's the air regulator I was talking about, so this will be an Easter task for me, regardless of whether this is the cure. Thanks.
And bingo, ECR33 Series 2 running a Power FC
If the tuner offered to look at it when it got colder I'd talk to him
Have a hand controller?
Watch the timing when the problem happens. Also watch the sensor/sw page for issues
The handcontroller is a little bit helpful in troubleshooting but will never be as good as logging on a laptop
If the other physical items like the air valves are operating fine, are you able to check the timing and fuel map?
Look for big changes in timing and fuel delivery in those load/rpm cells. A bumpy map can lead to oscillations in rpm due to lean-rich-lean cycles, or perhaps the same concept with timing.
Well, the latest. I removed the air regulator and was shocked to find..... It was clean. Very little residue at all, but I still fogged it with carby cleaner and reinstalled. Problem is still there, no surprise. Having run out of things I have the ability to check Ive decided Ill most likely take it to my tuner to diagnose. I also have a fuel economy problem so they can get both issues in one hit I think,
  • 3 weeks later...
Took it back to the tuner, he checked everything, all came up ok. He also did an idle reset of the power FC so it learned the idle again and we thought the problem was fixed, but as I went to drive home it happened again. It at least all seems less bad than initially was but the reason is a mystery. He did note that my intake gasket is leaking so Im going to change that out; who knows, it might in some way help too....
Just a couple of quick and easy things you can check. If you have a hand controller, try changing the return to idle fuel cut off. Try increasing or decreasing it and see if it has any effect. From memory that should be on the screen where you set the idle. Also make sure that your car is idling at what your set point is. E.g if the controller is set at 800rpm but the engine is idling at 850, adjust the iacv so that the idle matches the set point. This had happened on a previous car of mine and was causing all sorts of weird idle issues. I adjusted the iacv to match and it ran beautifully.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
