Looking to get the best sound out of my RB3025neo without being over the top loud, have read heaps of threads, want some fresh opinions
Setup details- RB3025neo , 260poncams, topmount, GT3076, 44mm tial, E85, 3 1/2inch dump and 100cell cat, current 3 1/2inch catback with jap middle muffler and X force large oval muffler..
Options so far
1) Cut jap middle muffler out and keep rest of system
2) HKS hi power 409 catback
3) cut Jap middle muffler out and replace X force muffler with Magnaflow, then add second Magnaflow if too loud...
So which will sound best , will a HKS catback with restrictors still be a restriction if using E85??
Edited by AngryRB
  • Like 1
https://www.sau.com.au/forums/topic/463757-hks-hi-power-catbacks/
overwhelming responses, thanks dudes lol..... went with HKS hi power 409 biches.. will include go pro footage in build thread in couple months for those interested :thumbsup:
Edited by AngryRB
So is the only difference between the Hi-Power and the Hi-Power 409 the type of steel?
I'm potentially interested in the Silent Hi-Power as I'm coming from an exhaust that may have given me permanent hearing damage. Looking to improve upon that. ;)
I put the Silent on my car a couple of weekends ago. It is loud. Too loud for my liking, but you may like it.
Hmm. Not that YouTube videos mean much, but it seemed relatively mild. I am looking for a quiet exhaust. I want improved performance, but if it sounded completely stock, that would be fine by me. If this is too loud, what system would you recommend? Are any quieter?
I've been reading about all the quiet ones, and it seems as though the GReddy Power Extreme II, Kakimoto Regu 06&R, and the HKS Silent Hi-Power are the top of the heap for quiet. But everyone's opinions on the best one are split (usually people just say the one they have is the best).
Seems to me, though, that the the Kaki and GReddy are pretty restrictive. The HKS is 3.75" (95 mm). So it may be the best compromise if silent is the goal but want to be able to build up HP without restricting.
No you get one custom made to make power and be streetable
If that's the case, what specifications would you recommend? I'm in the US where about 99% of exhaust shops won't even know what kind of car I'm driving. So some direction would be nice rather than spending $$$ on trial and error. Thanks!
Picked up the HKS hi power 409, i was expecting restrictions but this doesn't have the expected 2.5inch silencers, i had to google about exhaust size measurements and correct me if wrong, you measure OD right??
post-70965-0-62176400-1460016293_thumb.jpgpost-70965-0-57843800-1460016320_thumb.jpgpost-70965-0-58788400-1460016342_thumb.jpgpost-70965-0-83736200-1460016363_thumb.jpg
Seems the smallest part is the bit that will bolt to the cat , which is 3inch , this continues thru the small resonator we'll call it, then its 3.5inch, then at the flange it steps up to 3.85inch which goes thru the cannon then 5inch tip...
So this could be loud, we'll have to see but a thought a JASMA rated catback has to meet a decibel rating?? but with a GT3076, top mounted, and 3.5inch dump, maybe it will be much louder than Jasma hey...
Edited by AngryRB
  • Like 1
Yeah that will be loud.
Did your have the silencer in the rear or middle or does it look similar to this?
I can put a large Xforce muffler in the middle or Magnaflow, so should be ok for a weekender...
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
