Okay, just got back to melbourne.. decided to check out the conditions of the coil packs and spark plugs..
-Looks like I already have splitfires installed (no visual damage).
-NGK iridium bcpr7iex sparkplugs which looks in reasonable condition.
-The coil pack loom, visually looks like in good condition.
-It was running fine before so I highly doubt it's the tune.
I don't know the condition of the fuel filter, I'll change it however I'll have to wait till it comes in.
I've put everything back together and it runs fine. However, and just as before, sometimes it struggles and runs sluggish. Sounds like a WRX boxer engine...
Maybe it's time to go to the mechanics?
I had a problem with misfiring but ONLY under full boost, 24psi, (12psi was fine)
turned out my coil packs were shorting to earth so I made up some Acetal
mounting plates and the miss is GONE, car has never run smoother!!
I got the idea from an overseas forum where this fix was solving heaps of problems for people.
I was actually thinking of making some more up If people might be interested in purchasing them?
Edited by 85URE
Sorry for being noob! Is this a mounting plate for the coil packs?
Interested at this as I am having very random low rev/low boost misfiring at times.
Ended up being the coilpacks. One of them is faulty. When one of the coilpacks heats up, it starts missing.
To check coilpacks - disconnect them one by one, if the engine misses, that coil is fine, if it doesnt, that coil is faulty.
Replaced them and all good to go again.
Goes to show that even Splitfires can be faulted.
Thanks for the help guys! Problem solved!
  • Like 1
Yeah! Thing is, not many forum topics (or that I can find) describes failed splitfire coilpacks.
I hear that OEM is best, but no topic says that Splitfire is inferior in anyway as well.
In saying that, I bought the car with the Splitfires installed. So I don't know how long or how many kms it's been used for...
Splitfires are basically as good as OEM. If they are in service for a lot of years and especially if they are in an engine that cops a flogging across those years, they will age out, the same as the OEM ones do. Nothing lasts forever - it's just that most people haven't reached that age/flog level on Splitfires yet.
