NM35 Stagea with factory NISMO Aero body kit
$9500 ono
120,000kms
Reluctant sale as i am going overseas.
12 months Rego
It is in good condition and always run BP Ultimate petrol.
Serviced every 5000kms or less with Full Synthetic Oil
Dark tint on rear windows
Cargo Blind for boot
Factory Stagea Mats thoughout
New Radiator - not long installed.
Yellow Jacket Coils
IMPUL Coilover Suspension (Firm and bit lower)
BBS RGR Wheels ($4000) with Hankook Ventus Noble 2 Tyres (Tyres are brand new)
*LED driving night not included*
*Personalised Plates not included*
Adam - 0401 133 866
Located - Canberra/Cooma
  • 1 month later...
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
