Hallo y'all. I was wondering how te stock r34 brakes , with decent lines, oil and pads, perform for trackday use?
Do they deliver enough stopping power or is it advised to upgrade to gtr brembo's or evo calipers ?
I'm on the point to getting my gtt on the road and have to change my brake pads and discs and i don't want to spend money on something i have to change soon because it isn't enough ... [emoji3]
GT-t brakes are decent (enough).. being 310mm in diameter.
I used to run stock R33 GTS-t brakes, 296mm in diatmeter and they were decent for a 330kW boat at Wakefield Park. Coupled with Project MU HC800+ they could do about 4 laps before showing signs of fade.
When I mean fade, brakes would still work for 10 laps but require heaps of pedal effort.
I've since upgraded to BREMBO calipers with Intima Type-D (as I sell them haha)... car is destined for the track 30th May for a shake down.
I upgraded my C34 Stagea (which is probably heavier than your car) to GTT brakes with specially made pads from RaceBrakes and they worked well on the track. When I upgraded to an RB30 with a bigger turbo I felt the need to upgrade again.
And where you dritving street tires or semi's
? [emoji3] [emoji6]
Yeah they're fine but eventually you'll want more, as always.
I've got a $1,000 budget set up in it's been fine for Sandown and Calder in my full weight R34 sedan, though I'm not a brave braker (yet).
DBA discs, Remsa 650C cheapie pads, braided lines, high temp fluid, BMC stopper.
Details here: http://www.sau.com.au/forums/topic/448613-r34-gtt-brake-improvement-without-breaking-the-bank/
I ran last two track days with fresh R888R real semis with a skinny 225/45R17 square setup, no issues with braking performance (except uneven pad wear but that's a different story: http://www.sau.com.au/forums/topic/463353-post-track-day-qs-rotor-wear-gearbox-oil-ps-pump-manifold-nuts/ ).
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
