I really think I need to drive an Evo and an Sti back to back. I've driven an Evo 3, 6.5, 8 and X, but never driven a rex.
At the moment, an 05 Sti and a spare engine and gearbox ready to go seems like a good idea.
This is the last one with the 2L right?
yep thats the last of the 2L
If i bothered to read the first post properly.. GG retard.
You can't really have both reliably. Even if you do want to mix them, if you break said car at the track it can put you up shits creek.
Like i said, personally.... I would go an Emo over a WRX any day. Specifically a IX. They are relatively comfortable, the back seats are actually surprisingly comfortable if people need to use them. Good on the road and their reputation speaks for themselves on the track. Just flash the ECU and wind the boost up. Job done. From factory they are a fantastic package.
  • Like 2
same wavelength :)
And if bored, run flex fuel say with a Haltech and crank out over 250kW on E85 or just a basic dual map (which is ok too) on stock ECU
personally, if i wanted something I could thrash and not care about, but also plan to keep it reliable (and affordable), i would get an N/A POS and give zero f**ks.
There is a Mazda 121 bubble in Vic that runs semi's and a half cage. The guy who runs it is always the happiest at any track day. May not be the fastest on the straight, but the thing just keeps chugging along and is fun.
Personally, I would do the civic route. light, heaps of aftermarket bits (a lot of them cheap), decent on fuel, tyres dont cost a fortune and neither does general or major servicing. Anyone who has done a major service (diffs+gearbox fluid) on a late Evo usually has a small tear build-up in their eye whenever they have to talk about it.
  • Like 2
I reckon Leroy is on the money.
Imagine spinning a new RS into the gravel. Just think of those lovely sounds of stones hitting the underside of your new, shiny, $50k car. Wouldn't that be lovely....
Now put yourself in something that gets you around in relative comfort but is cheap and you don't really give two f**ks about.
RX-8s are cheap as shit and plenty of parts around for them (ignore the rotary haters).
Mini Cooper S are also cheap as and have a huge aftermarket. Would need heavily tinted windows when on the street, but it'd be a weapon on the track.
Low K's Fiesta ST can be had for under $20k. XR-5 Focus can be had for the same, but a few more K's and I imagine repair costs when something breaks would be eye watering.
A Manual FG XR6 (non-T) with under 50,000ks can be had for about $17k. A few grand for some big brakes, track spec wheels and rubber and a couple grand on some coilovers and that would be a weapon for a smidge over $20k.
350Z Tracks can be had for sub 20s with under 100,000ks.
Lots of cool options.
  • Like 1
have you driven both for a good length of time? Have you worked on both?
yes.
But, haven't driven wrx on the track.
Loved my emo on the track, multiple days with little trouble.
Also, consider the sti hatch.
Drop down rear seats, and hatch room would make a suitable weekend mover.
Sti also has the brembo calipers, but, no seat heaters or proximity entry and start.
Emo doesn't has drop down rear seats.
I had a brain snap the other day when I realised if I wanted to do a track day at Wakefield (which is most track days) I would probably tow the car there anyway thus negating the value of having a track car with rego.
So... the Skyline stays I guess! Might consider moving into something a bit easier to manage but for now I just want to use it.
Still wanna sell the F6 and maybe get a rex or evo and take it to Marulan and the odd track day when I cbf'd taking the skyline.
Anyway appreciate everyone's advice. Cheers :cheers:
  • Like 1
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
