V28VX37 Posted March 25, 2016 Share Posted March 25, 2016 Hi guys, I did a quick search but can't find a clear answer: What's the largest verified brake kit you can fit behind R34 GTT stock 17" wheels? I'm running 20mm spacers too so have more clearance behind the spokes. I'd love to run the 350mm disc + Evo 9 caliper conversion but I'm not convinced it'll fit. I really want to avoid changing rims as I have two sets of these, with good new street and track rubber.. Thanks heaps Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/ Share on other sites More sharing options...
Ben C34 Posted March 25, 2016 Share Posted March 25, 2016 Look at how much clearance you currently have and do the simple maths Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7702316 Share on other sites More sharing options...
V28VX37 Posted March 25, 2016 Author Share Posted March 25, 2016 Look at how much clearance you currently have and do the simple maths Will do, although I'm not sure about the simple part as all calipers are slightly different shapes and sizes..? Ideally I'm keen to hear that someone runs XYZ calipers with 3xx mm discs and stock wheels with no issues. Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7702334 Share on other sites More sharing options...
hardsteppa Posted March 25, 2016 Share Posted March 25, 2016 Buy evo kit, try it. Sell to me cheap if it doesn't fit. Win. Well, win for me. But really, i'm similar, have 17in drifteks and think it mayyyy squeeze in but would be tight. Saw evo10 brakes last weekend, theyre huge. Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7702337 Share on other sites More sharing options...
V28VX37 Posted March 25, 2016 Author Share Posted March 25, 2016 Buy evo kit, try it. Sell to me cheap if it doesn't fit. Win. Well, win for me. But really, i'm similar, have 17in drifteks and think it mayyyy squeeze in but would be tight. Saw evo10 brakes last weekend, theyre huge. Did you try the wheel on? Would love to know how close it is.. I had 350mm AP racing kit on my previous car, they're big brakes. Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7702338 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 3, 2016 Share Posted April 3, 2016 Doubt you'll get 350mm EVO brakes inside of a 17" wheel. I'm running 350Z Brembos and there is about 8mm of wheel clearance vs. caliper with 17" R33 GTR wheels. 1 Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7706354 Share on other sites More sharing options...
V28VX37 Posted April 4, 2016 Author Share Posted April 4, 2016 Doubt you'll get 350mm EVO brakes inside of a 17" wheel. I'm running 350Z Brembos and there is about 8mm of wheel clearance vs. caliper with 17" R33 GTR wheels. That's a 324mm disc from memory? Similar to 33/34 GT-R factory Brembos? Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7706780 Share on other sites More sharing options...
Ad's Posted April 4, 2016 Share Posted April 4, 2016 Doubt you'll get 350mm EVO brakes inside of a 17" wheel. I'm running 350Z Brembos and there is about 8mm of wheel clearance vs. caliper with 17" R33 GTR wheels. 350mm evo 10 rotor with Evo 6 Brembos here and I have 17's over them. Its all to do with the inner barrel, if it steps then you have no hope. Currently running teks atm and I'm in the process of selling them and want to stay something in the 17inch range. Any Japanese wheel that has a non stepped barrel should clear them depending on spoke design and offset. Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7706837 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 4, 2016 Share Posted April 4, 2016 That's a 324mm disc from memory? Similar to 33/34 GT-R factory Brembos? Correct, but offset is slightly different Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7706839 Share on other sites More sharing options...
V28VX37 Posted April 4, 2016 Author Share Posted April 4, 2016 350mm evo 10 rotor with Evo 6 Brembos here and I have 17's over them. Its all to do with the inner barrel, if it steps then you have no hope. Currently running teks atm and I'm in the process of selling them and want to stay something in the 17inch range. Any Japanese wheel that has a non stepped barrel should clear them depending on spoke design and offset. Thanks – Would you happen to know the inner diameter of the Teks at all? Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7706840 Share on other sites More sharing options...
KiwiRS4T Posted April 4, 2016 Share Posted April 4, 2016 I ran a number of different aftermarket 17in wheels with 330mm D2 Brakes (and they were fine at the track with my 1700kg Stagea). I don't think your GTT wheels will fit over 350mm brakes - why don't you track down some members with big brakes and ask if you can try a GTT wheel on - then you will know for sure 1 Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7706851 Share on other sites More sharing options...
Robzilla32 Posted April 5, 2016 Share Posted April 5, 2016 I have the AOR Brembo front and rears on my R32 GT-R if you want to try a wheel on for size 1 Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7707009 Share on other sites More sharing options...
V28VX37 Posted April 11, 2016 Author Share Posted April 11, 2016 Ok so I took some measurements of the R34 GTT stock wheels tonight: Wheel size is 17x7.5" (yes they're skinny) and I'm pretty sure offset is +40 (it says 40 and SK40 on the inside spokes), plus I'm running 20mm spacers all around ~390mm inner diameter at the wheel mounting surface (the line you see in the photo) ~415mm inner diameter at the wider barrel ~78mm wheel face to mounting surface ~120mm wheel face to wider barrel My current caliper clearance is about 18mm, measured from the caliper edge to the narrow part of the barrel. As mentioned I would love to run the Evo 350mm kit but I'm pretty sure it won't clear, would love to test it though! If anyone can confirm inner diameter of their aftermarket 17" wheel (at narrowest point) and which larger-than-stock discs and calipers they're running, that'd be ace Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7710286 Share on other sites More sharing options...
Kinkstaah Posted April 11, 2016 Share Posted April 11, 2016 I have a d2/ksport 356mm kit you can try if you like btw! Pretty sure it won't fit though but hey who knows, one of the more common upgrades 1 Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7710305 Share on other sites More sharing options...
V28VX37 Posted April 12, 2016 Author Share Posted April 12, 2016 Ok I know that I just need to go and trial fit the wheel over some actual brake setups but ... in the meantime did some back-of-the-envelope calculations for different rotor sizes: Rotor|Surface+|Volume+ 310 | - | - 324 | 17% | 15% 330 | 25% | 22% 343 | 42% | 37% 350 | 52% | 45% These are all somewhat optimistic figures, assuming that the disc surface start radius is the same for all sizes, 30mm rotor thickness, and 25% hollow rotor volume. Anyway what I was trying to work out is whether the 33/34 GT-R 324mm Brembos would be a worthwhile upgrade – I don't think so. I think the main options keeping the original rims are the 343mm and 330mm rotors (or thereabouts) – which size is most common in terms of disc & caliper (read: the most affordable to acquire and replace)? Cheers Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7711078 Share on other sites More sharing options...
Ad's Posted April 14, 2016 Share Posted April 14, 2016 Quickly measured the teks before selling them. Hub was 400mm and the outer rim was 425mm. And they were tight but never fouled on anything. Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7712678 Share on other sites More sharing options...
V28VX37 Posted April 14, 2016 Author Share Posted April 14, 2016 I have the AOR Brembo front and rears on my R32 GT-R if you want to try a wheel on for size Thanks man, is that with the 350mm front discs? 350mm evo 10 rotor with Evo 6 Brembos here and I have 17's over them. Its all to do with the inner barrel, if it steps then you have no hope. Currently running teks atm and I'm in the process of selling them and want to stay something in the 17inch range. Any Japanese wheel that has a non stepped barrel should clear them depending on spoke design and offset. Quickly measured the teks before selling them. Hub was 400mm and the outer rim was 425mm. And they were tight but never fouled on anything. Brilliant thanks mate! I'd say the 350mm setup is out then, though it would be great to test it with the 20mm spacer on... I'll keep an eye out if anyone has 343's or 330's for a quick trial fit Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7712729 Share on other sites More sharing options...
Robzilla32 Posted April 14, 2016 Share Posted April 14, 2016 Thanks man, is that with the 350mm front discs? Yep Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7712754 Share on other sites More sharing options...
V28VX37 Posted April 15, 2016 Author Share Posted April 15, 2016 YepCool thanks, I might take you up on the trial for offer, will pm tonight Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7712972 Share on other sites More sharing options...
Robzilla32 Posted April 15, 2016 Share Posted April 15, 2016 Cool thanks, I might take you up on the trial for offer, will pm tonightSure let us know. Link to comment https://www.sau.com.au/forums/topic/463836-largest-brakes-under-r34-gtt-stock-17-wheels/#findComment-7713126 Share on other sites More sharing options...
