Pete your entry looks wrong, it says skyline not filthy cheater evo?
Its a good long entry list overall, so hopefully the event will last a few years unlike last time. Some very fast stuff in the supersprint group too...
Ok here are the people I know from VIC on SAU
Lightning Sprint Group B
7    Christopher Thomson    Scottsman    Nissan GTR    FB    VIC
Lightning Sprint Group C
21    Andrew Richmond    Snowman    Porsche Cayman GT4    AA    VIC
79    Matthew Lowth    Matthew Lowth    Lotus Exige    AA    VIC
Thunder Regularity Group A
31    Andrew Collins    acsplit    Nissan R31 Skyline    VIC
93    Craig Ferdinands    13 Crag   Audi RS5    VIC
86    Jonathan Lawson/ John Richardson    Jonathan Lawson/ssrRicho    Subaru V5 GC8    VIC
Thunder Regularity Group D
555    Christopher Starr/ Chris Madden    Christopher Starr    BMW 328i    VIC
On 11/7/2016 at 6:24 AM, Roy said:
I cancelled in disgust. Too many VWs and EVOs and only  one real man in an R31
Well there is Lee in the 260Z, still L engined too, very experienced driver in what would be around the oldest car in the Sprints. Going to get blown away on the straights :)
Edited by 260DET
Last time the event got cancelled by the council due to the event organizers doing naughty things rather than due to a lack of support.
James O'Brien (original 12hr guy and current 6hr guy) is running this so I think it will remain strong. This year there was a clash with 12hr cars and the trip to NZ for the Highland 101 so I expect next year you'll see a LOT more 12hr cars etc at the event and it will be a real testing showcase. Hopefully we can still get sprint spots in road cars. I'm hoping to crack under the 2:30 mark in the mini croc. Have now gone over 1s faster at PI than I have in the EMO and I was oh so close in that at Easter this year.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
