At least the emo won't try and grenade itself.
Or maybe it will.
I'd own a 34. But f**k paying that much for one in this market.
I agree. U could buy a brand spanker evo x and have change and warranty. Its a no brainer, except its like selling your soul to the devil[emoji12]
  • Like 1
https://www.sau.com.au/forums/topic/463870-evo-drive/#findComment-7703465
An ex workmate of mine has one, he modded and maxed out the stock turbo at around 300awkw on e85. Engine eventually threw a rod and he spent an arm and a leg on a new block with cosworth internals and FP turbo for a reliable 500awhp. Don't work with him any longer so can't say how its held up in the year or so its been at 500whp.
  • Like 1
https://www.sau.com.au/forums/topic/463870-evo-drive/#findComment-7703467
At least 2 less cylinders to worry about when rebuilding.
Anywho,
Drove the car. Makes my 33 feel as old as it is.
-Steering is very responsive with good feedback.
-Brakes are amazing for standard rotors and pads.
-It's slow. But what do you expect from a standard car.
-Chassis is stiff af. Coilovers contributed to bumpiness. Momma ain't raise no pussy.
-Gearbox feels nice.
-Seats are great. Those emo recaro's are so good.
-Engine bay has lots of space.
I can see why these things do so good at the track. There is no real sloppy feel anywhere. Give it a exhaust and put e85 in the tank with a tune and I reckon it is a perfect car for driving on the road and being a weekend track warrior.
TLDR Probably going to sell my soul.
  • Like 2
https://www.sau.com.au/forums/topic/463870-evo-drive/#findComment-7703651
it's a sad reality, but R32/33/34 Skylines GTS-t GT-Rs are pretty much all siet boks compared to newer cars.. heck a Ford Focus RS would munch hard... imagine a basic modded Ford Focus RS.. would clean up a a GT-R with 50k worth of mods.
https://www.sau.com.au/forums/topic/463870-evo-drive/#findComment-7703669
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
