Out of curiosity I googled "stock times at Wakefield" and saw this:
-Porsche 911 GT2 (997) 1:05.05
-Lamborghini LP640 1:06.70
-Porsche 911 GT3 (997) 1:07.40
-Porsche Carrera S 1:08.50
-Mercedes CLK63 Black 1:08.60
-Mitsubishi EVO IX 1:09.39
-Audi TTS 1:09.40
-Mitsubishi EVO X 1:09.50
-BMW 135i Coupe 1:09.90
-FPV F6 08' 1:09.90
-FPV F6 (auto) 1:10.10
-Subaru WRX STi (My05) 1:10.10
-Nissan 350Z Track 1:10.30
-Lotus Exige 1:10.66
-Mazda FD3S 1:11.50
-Ford XR6 Turbo UTE 1:11.70
-Mazda RX8 1:11.80
-Nissan S15 ADM 1:12.50
-Mazda 3 MPS 1:13.00
-Honda DC2R 1:13.00
-Honda DC5R 1:13.00
-Peugeot 207 GTi 1:13.50
-Renault Clio 197 1:13.70
-Mitsubishi Ralliart Colt 1:14.00
-Alfa Romeo 147 GTA 1:15.00
-VW Golf R32 1:15.00
-Ford Fiesta XR4 1:15.40
-Peugeot GTi6 1:16.00
-Mazda 3 Sedan 1:20.90
Some of those seem pretty underrated/responsive to mods as well.
I don't know of anyone going from a souped up GTR to a Stock 350Z anytime soon. Put a pro driver in your R33 GTR and see what they do relative to us mere mortals :P
I do personally rate the Evo X though. I have driven one and a friend has one. 220kw at the wheels and some Ohlins + AD08R's and you're like, well, what else do you really need?
  • Like 1
Drove the car. Makes my 33 feel as old as it is.
I think you've just been stuck in skyline-mode with rose coloured glasses.
personally i dont find skylines are that special either. Evo's are fairly special (in a not-cool way) but plenty more interesting things to drive around.
Drive one for a bit, but keep in mind everyone on SAU sells their Evo eventually when they realise it isnt very exciting unless driven like a maniac (and then what car isnt exciting when driven to the limit?)
I always justify how much I spend on the pulsar by thinking "at least its not a GTR" because seriously everything I do is like half the cost of GTR equivalent.
Maybe that is the case and my eyes are now opened.
Or maybe my eyes have been opened to see what happens when you hit the track multiple times only to be competed against a near stock Evo.
Or to be schooled on a skid pan. These are the things to consider in my case.
And the missus likes it. But she likes the fatty too. Says she will need some time adjusting.
135i?
They can be flash tuned to some silly number too. Plus, you get all the other niceties of a BMW.
Still RWD, Still Manual, if that's your thing.
Obviously an AWD turbo is easier to just add power and have that added power translate to forward momentum :P
  • Like 1
There's a trick to tuning EVOs you either progressively build boost after peak torque, or purely run very low timing at peak torque.
You can happily make 350awkW on an EVO and not throw rods if you know what you're doing.. also by progressively building boost after peak torque or simply running less timing at peak torque and as you get to peak torque you'll end up with a flatter torque curve.
Is that to me or zebra?
Just stated a fact that's all, no dick waving here, just a shame some people perceive a post that way because they have a dick up their arse, and yes evos are great cars but u can't push them like you can push an rb in stock form.
By the way zebra never seen an rb blow up by turning the wipers on, dickwad.
  • Like 1
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
