SAUNSW Club Entry for
2016 GTR Festival
SAUNSW has been invited by Motive DVD to have a club display displaying members cars at the 2016 GTR festival
This means you will have the opportunity to have your GTR displayed together with other SAUNSW members GTRs at a discounted rate to normal admission.
You will be part of the biggest gathering of GTRs outside of Japan ranging from R35 GTR to the Hakosuka
There will also be the following at the show
  • Drag racing
  • Go to whoa
  • Launch pad
  • Dyno Comp
  • GTR car yard
  • GTR swap meet
  • Various trade stands
​To enter these events visit http://motivedvd.com.../gt-r-festival/
To enter your GTR in the club display please fill out the form attatched below and email back to <script data-cfhash='f9e31' type="text/javascript">/* */</script> and pay entry as per the entry form
Event: 2016 GTR festival
When: Saturday 28th May 2016
Where: Sydney Dragway
Cost: $30
Entry Form: doc.gif 29.5KB 16 downloads
Club display is unfortunately ONLY open to GTRs but event is open to all spectators.
Spectator tickets can be purchased from here http://motivedvd.com.../gt-r-festival/
^^ as other thread ill take the R.
Provided it's back.
What's left to do?
Mine was on dyno today. I asked them to hold out a bit cause I was going on holidays so shouldn't be too long now.
What's left to do?
Mine was also on said dyno today.
Just a couple of tiny little things holding it up.
For example:
The HKS aiflow less adapters had a different pattern to my pod filters... as the POD filters fit the Z32 AFMs i had. I completely forgot about the fact they were Z32's and not standard ones lol. So got my old ARC box probably going in, need filters for it... So Either finding filters cheap till i purchase a new one (arc box), or i will get a set of cheap pods to suit my HKS adapters until the new one (arc box) arrives.
Couple of little A/C checks...
And then put some of the interior back together..
and it's finished.... Provided nothing else dies on me.
  • 4 weeks later...
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
