Model Nissan Skyline GTR V-spec (R33 series 1)
Year 1995
Colour Silver
Mileage 120,000kms
Location Wantirna, VIC
I have owned this car since 2008, all work and servicing has been performed by Racepace in Melbourne. My intention has been to build a car that drives well on the street but can also perform well at track days. Unfortunately, I have never made it to any track days and the car does not currently get used enough or for what it was intended. The car appears stock in appearance so the new owner should not have any problems driving it on the street.
Engine
Built and tuned by Racepace 385rwkw
Nissan N1 block - blueprinted
HKS Step 2 2.8L engine kit
Tomei oversized oil pump
N1 water pump
Racepace head, Tomei bype B valve springs
Nissan standard spec cams
OS Giken adjustable cam gears
Nismo AFM's
HKS -5 turbos
Racepace RPM circuit baffled 9L sump
Racepace remote oil cooler under LH guard
Racepace 90mm exhaust with twin tips
Racepace catch can
Greddy 50mm aluminium radiator
HKS 100mm intercooler
Apexi Power FC
Drive Train/Suspension
Nismo Super Coppermix twin plate clutch
Standard Brembo brakes with Benndix Ultimate pads
Tein RS coilovers - re-valved and dyno tested
Cusco front upper arms modfied to RPM spec
Cusco Tension Rod/Castor Rods
Wheels/Tyres
BBS LM 18 x 9.0
Kuhmo KU31 265/35
Interior
Nismo instrument cluster
Nismo meter gauges
GTR floor mats
Alpine Stereo with ipod connection
Price $27,000 negotiable
Please PM me for more details or to arrange an inspection.
Warren
https://www.sau.com.au/forums/topic/463881-1995-racepace-gtr-hks-28/
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
