Hey guys, installing a oil cooler and relocation kit
Looking at mounting the cooler in front of the radiatorbut there are 2 lines(backed on itself )in the way.
Ive traced one end back to the power steering fluid resovoir but unsure of where the other side ends, i assume its some sort ot cooler ( pictures attached )
So my question is can i get a relocation kit for this and any other preferable mounting positiongs for the cooler, i cant see where the mount is possible behind the front bar left or right side.
Cheers, kind regards
Have you um checked anyone else's setups?
Majority of setups are where these lines are or under the front bar infront of the air ducts on the left or right side
Does anyone know if you can get a relocation kit for the power steering lines as i am unable to find
Cheers
Yes it's for R33 but pretty much all the possible oil cooler location options are documented in this thread: http://www.sau.com.au/forums/topic/79130-r33-oil-cooler-installation/
I read it top to bottom before installing mine, great info.
Ideally you'd want your oil cooler under left or right headlight behind the front bar so it's not in line with intercooler, A/C core and radiator.
However depending on the size of your oil cooler core this may not be possible, especially presuming you have IC piping running on both sides since it's a GT-R.
hey mate, yeah isnt a whole lot of room with the IC piping, cheers for that link i had a read, and ill have another look for potential spots tommorow.
thinking of relocating the power steering lines to fit the it infront of the ac core. not ideal spot but im not sure it will fit under the head lights.
regards
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
