Ben C34 Posted June 12, 2017 Share Posted June 12, 2017 22 hours ago, AngryRB said: Had a big win today, the exhaust although sounded great under boost was droning and too loud in traffic so I made a holmz heltz resonator chamber. It's maybe working too good as its super quiet now, who would of thought a big cannon could be quiet and cost me nothing ?... my welding is super amateur but it works ... When I get time I'll make a series of different lengths and fine tune it.. Thats awesome! Welds on an exhaust are just to hold it together and not leak, don't need to look good! GReat to see a truly budget exhaust and not drone! Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7834503 Share on other sites More sharing options...
Ben C34 Posted June 12, 2017 Share Posted June 12, 2017 Did I miss the skid video? Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7834504 Share on other sites More sharing options...
AngryRB Posted June 13, 2017 Author Share Posted June 13, 2017 On Monday, June 12, 2017 at 0:11 PM, Kane_R32 said: any effect on performance? Nah don't think so, no difference in knock... Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7834727 Share on other sites More sharing options...
AngryRB Posted October 13, 2017 Author Share Posted October 13, 2017 (edited) Not much update, but shes still alive.. Just doing maintainence and driving it when i can, theres plenty of tweaks needing done such as cam gear adjustments, boost controller doesnt work properly and cold start is rough. But all things considered its impressive the pull on 1bar from 3000rpm.. Will eventually get a go pro to demonstrate some pulls and drag times.. Edited October 13, 2017 by AngryRB 3 Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7854242 Share on other sites More sharing options...
AngryRB Posted November 28, 2017 Author Share Posted November 28, 2017 (edited) Im enjoying driving the car but cant help but wonder if i can improve the response. I recorded a few pulls, i want to have it responsive as possible so maybe i need a diff change as well as cam timing play on dyno and boost controller working to get the most out of the setup.. This short clip was a 3rd gear pull from 2000rpm and it just doesnt get stuck in till 4000rpm..tge vid doesnt show but its pulling hard at 3600rpm.. Im thinking a 3.7 ratio may help...hmm Edited November 28, 2017 by AngryRB Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7860525 Share on other sites More sharing options...
klutched Posted November 28, 2017 Share Posted November 28, 2017 You make 15psi about 400rpm before me. Change ecu to a link/haltech and get closed loop boost setup through that instead of your boost controller. Boost will probably be a lot smoother as well. Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7860555 Share on other sites More sharing options...
AngryRB Posted March 21, 2018 Author Share Posted March 21, 2018 Decided to do some heat management, the tial gate has changed from black into purple.. Also got some bungs put in the dump so i can later get a wideband and exhaust temp guage hooked up... I noticed there was no duty cycle dialled in for low end spool so i set it to 100% uptil 3k rpm and its alot better but there no traction from 3.5krpm, its badly needing a diff and setup to lay it down... Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7870683 Share on other sites More sharing options...
AngryRB Posted August 29, 2018 Author Share Posted August 29, 2018 Car developed a rattle noise on cold start, so ordered a brand new VCT gear and solnoid. Fitted them up after fitting the ring to make the VCT adjustable again. Fired her up and noise has gone. 1 Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7884129 Share on other sites More sharing options...
Dose Pipe Sutututu Posted August 30, 2018 Share Posted August 30, 2018 car goes harder now? Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7884220 Share on other sites More sharing options...
AngryRB Posted August 30, 2018 Author Share Posted August 30, 2018 8 hours ago, Dose Pipe Sutututu said: car goes harder now? Will find out soon, waiting on a new battery as sitting so long has stuffed the battery.. Chasing an issue where it fires on 5 cylinders, what would cause cylinder 3 to not fire? Ive changed plugs, new coil and now coilpack harness. Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7884284 Share on other sites More sharing options...
klutched Posted August 30, 2018 Share Posted August 30, 2018 4 hours ago, AngryRB said: Will find out soon, waiting on a new battery as sitting so long has stuffed the battery.. Chasing an issue where it fires on 5 cylinders, what would cause cylinder 3 to not fire? Ive changed plugs, new coil and now coilpack harness. Injectors? Had a problem with a 33 had intermittent firing issues on cyl 3 but was something broken in the head. Would be ok sometimes then die sometimes. Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7884314 Share on other sites More sharing options...
AngryRB Posted September 6, 2018 Author Share Posted September 6, 2018 Battery finally arrived, decided to splash out and get something decent. Shes a D34 yellow top, 750cca should be enough grunt. The battery tray i think will need widened but will be fine. Also got some more Mobil and zddp additive, even 0-40w and she doesnt use any oil ? Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7884844 Share on other sites More sharing options...
AngryRB Posted September 6, 2018 Author Share Posted September 6, 2018 On 8/31/2018 at 12:06 AM, klutched said: Injectors? Had a problem with a 33 had intermittent firing issues on cyl 3 but was something broken in the head. Would be ok sometimes then die sometimes. Could be but there new injectors, before the VCT replacement it would randomly not fire cyl 3 on cold start but after 5mins fire all 6. Once batteries in ill check the coil is sparking and maybe take the injector out. Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7884845 Share on other sites More sharing options...
klutched Posted September 6, 2018 Share Posted September 6, 2018 5 hours ago, AngryRB said: Could be but there new injectors, before the VCT replacement it would randomly not fire cyl 3 on cold start but after 5mins fire all 6. Once batteries in ill check the coil is sparking and maybe take the injector out. Just unplug the coil and if it doesnt change unplug the injector Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7884862 Share on other sites More sharing options...
AngryRB Posted September 19, 2018 Author Share Posted September 19, 2018 (edited) She's alive again, feels much better low down and spools up early... Love this idle.. Edited September 19, 2018 by AngryRB 3 Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7885842 Share on other sites More sharing options...
AngryRB Posted October 29, 2018 Author Share Posted October 29, 2018 Got the shits with this 5cylinder start ups so now shes at the tuners. But now apparently it wont start at all, bloody cars.. the day before i checked the injectors, coils all fired, plugs mint, did a comp test, motor cold. Cyl 1-6: 165,170,175,175,168,170 So happy with that considering the tomei cams drop about 25psi off. So hoping its a cheap fix but im thinking ecu maybe giving up, if so im gonna get a haltech elite 2000 or 2500 ? Had a few good squirts on the way, ripping 2nd never gets old.. Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7889421 Share on other sites More sharing options...
AngryRB Posted September 29, 2019 Author Share Posted September 29, 2019 Its been a while, i got the shits and left it parked in the shed. Recently i pulled the injectors out and had them cleaned. I was told that it took 80psi just to get them to open, was almost a throw away deal. Probably cause i left it parked for months, when i dismantled the fuel system i could feel the stickiness of parts. So i replaced reg, fuel lines, filter and injectors cleaned and she starts on all 6 now with very little cranking. Probably need a retune now, doesnt smell of fuel and very little knock on the power fc so must be close. I missed the sound of it coming on boost, is like a jet aircraft, plenty of fun ???? received_1139692989569807.mp4 3 Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7916850 Share on other sites More sharing options...
AngryRB Posted October 23, 2019 Author Share Posted October 23, 2019 Had it at the tuners for a check up and turns out there is dramatic difference in the fuel pressure between the new reg and the stock reg so shes been running lean. On the dyno she sprung a big coolant leak at the back of the head so on the tow truck home... Now i have to pull the motor half out to fix what i think is a welch plug backing out. That sinco mani and 3076 though.... ???? 2 Link to comment https://www.sau.com.au/forums/topic/463908-angryrbs-project-series-1/page/4/#findComment-7918344 Share on other sites More sharing options...
