Can't wait to get grilled. Can't wait.
SCENARIO:
I have an R33 GTS-t which 2 years ago I converted to a complete Aspirated setup (L Plates).
I now have a daily which I use 99.9% of the time but I still enjoy my R33 on odd occasions.
I want to revive my RB25 back to it's original turbo form because I'm still absolutely in love with the R33.
[Keeping in mind I'm still a Green P Plater (19y.o.)]
- When I do this:
> No FMIC
> RB20/RB25 turbo depending on which turbo has lowest chance of detonation on my RB
> Have a heat plate rigged up to hide the turbo as much as possible
> Will run the lowest psi physically possible
I've never lost a demerit point for speeding, that's not why I want to run the turbo.
I'm not interested in performance increase/decreases, I'm interested in having my R33 back in
it's beautiful original turbo form with the health of the motor at 100% consideration. I drive the car
to the beach on the odd occasion maybe once a month, that's the only use it gets.
Thanks for reading, someone please respond from a thermodynamics perspective.
Not possible. No-one here has a good enough grasp on the thermodynamics, nor is it likely that anyone has the experience of running a DET engine with one or the other turbo without a cooler.
Here's my advice. Don't consider an RB20 turbo. Too old, too small. RB25 turbo all the way, Probably even an OP6 to get the bigger ex housing and reduce exhaust back pressure a little. Install a fricken intercooler. Factory sidemounts are laid up in piles at the wreckers. But even if you don't the standard wastegate setting is 5 psi and you will not detonate running that pathetic amount of boost. It will barely heat the air up 30°C. There's the only thermodynamics I can put into the discussion.
Here's my advice. Don't consider an RB20 turbo. Too old, too small. RB25 turbo all the way ....... the standard wastegate setting is 5 psi and you will not detonate running that pathetic amount of boost. It will barely heat the air up 30°C.
Appreciate your response, I had a feeling I was going into this setup in the dark. It's only for a few months so maybe the RB25 turbo is the appropriate temporary
solution until I can safely put my GT30 back on it.
Do you mean no FMIC, or no intercooler at all?
The sensible option (if any, really) is use the turbo the ECU is expecting to see, which would be the R33 turbo. Realistically for the engine size its a really, really small turbo as is.
If its legal in a few months, spend the months getting the GT30 setup right and just drive it then.
the lowest psi you can run is the gate spring, on the RB25 manual tuborcharger from memory it is 7psi, on the auto RB25 turbocharger it is 5psi from memory.
if you want lower boos than this, then you can simply wire the wastegate flap open and youll probably get 1 or 2psi if you are lucky at full load
ECR33 manual is 385mmhg which is 7.4446 psi
ECR33 auto is 270mmhg which is 5.220 psi
I'm trying to read between the lines a bit here...
So, you are worried about getting fined for driving a turbo skyline on your P's, therefore you don't want to run a sidemount intercooler because you think it will increase the chances of getting caught?
If this is the case, just install the factory sidemount and cross your fingers that you don't get caught.
If someone (said highway patrol officer) can spot a factory sidemount, they can spot the difference between extractors and a turbo exhaust manifold. So your screwed anyway. Might as well not take the chance on damaging your motor as well.
But of course common sense says you've been waiting a fair amount of time already, might as well just wait that little bit more.
Running a car designed and fitted with an intercooler from factory without an intercooler is not clever, from both a logic and "thermodynamics" perspective.
Driving a turbo car on your P's is stupid, just wait until your fulls. Is stock R33 turbo power really that exciting that you'd risk lots of money and your licence for?.. No it really isn't.
My advise would be get a hi flowed turbo and bolt it together with the standard manifold..
Must better turbo and no worries with detonation and options to increase boost..
You can pick a good one up for around 1k give or take a couple hundred
I think the gate is 5psi but the solenoid bleeds it to 7 or something like that. R32 have 10psi gate spring.
you are correct
If you want to run no intercooler, best to go E85 or WMI
Rb30et had no intercooler standard and they didn't sht themselves.
If it used to be running a gt30, that would be harder on the motor than the little r33 7psi setup.
And they ran a stupid low compression ratio as part of the no intercooler package.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
