Can't wait to get grilled. Can't wait.
SCENARIO:
I have an R33 GTS-t which 2 years ago I converted to a complete Aspirated setup (L Plates).
I now have a daily which I use 99.9% of the time but I still enjoy my R33 on odd occasions.
I want to revive my RB25 back to it's original turbo form because I'm still absolutely in love with the R33.
[Keeping in mind I'm still a Green P Plater (19y.o.)]
- When I do this:
> No FMIC
> RB20/RB25 turbo depending on which turbo has lowest chance of detonation on my RB
> Have a heat plate rigged up to hide the turbo as much as possible
> Will run the lowest psi physically possible
I've never lost a demerit point for speeding, that's not why I want to run the turbo.
I'm not interested in performance increase/decreases, I'm interested in having my R33 back in
it's beautiful original turbo form with the health of the motor at 100% consideration. I drive the car
to the beach on the odd occasion maybe once a month, that's the only use it gets.
Thanks for reading, someone please respond from a thermodynamics perspective.
Not possible. No-one here has a good enough grasp on the thermodynamics, nor is it likely that anyone has the experience of running a DET engine with one or the other turbo without a cooler.
Here's my advice. Don't consider an RB20 turbo. Too old, too small. RB25 turbo all the way, Probably even an OP6 to get the bigger ex housing and reduce exhaust back pressure a little. Install a fricken intercooler. Factory sidemounts are laid up in piles at the wreckers. But even if you don't the standard wastegate setting is 5 psi and you will not detonate running that pathetic amount of boost. It will barely heat the air up 30°C. There's the only thermodynamics I can put into the discussion.
Here's my advice. Don't consider an RB20 turbo. Too old, too small. RB25 turbo all the way ....... the standard wastegate setting is 5 psi and you will not detonate running that pathetic amount of boost. It will barely heat the air up 30°C.
Appreciate your response, I had a feeling I was going into this setup in the dark. It's only for a few months so maybe the RB25 turbo is the appropriate temporary
solution until I can safely put my GT30 back on it.
Do you mean no FMIC, or no intercooler at all?
The sensible option (if any, really) is use the turbo the ECU is expecting to see, which would be the R33 turbo. Realistically for the engine size its a really, really small turbo as is.
If its legal in a few months, spend the months getting the GT30 setup right and just drive it then.
the lowest psi you can run is the gate spring, on the RB25 manual tuborcharger from memory it is 7psi, on the auto RB25 turbocharger it is 5psi from memory.
if you want lower boos than this, then you can simply wire the wastegate flap open and youll probably get 1 or 2psi if you are lucky at full load
ECR33 manual is 385mmhg which is 7.4446 psi
ECR33 auto is 270mmhg which is 5.220 psi
I'm trying to read between the lines a bit here...
So, you are worried about getting fined for driving a turbo skyline on your P's, therefore you don't want to run a sidemount intercooler because you think it will increase the chances of getting caught?
If this is the case, just install the factory sidemount and cross your fingers that you don't get caught.
If someone (said highway patrol officer) can spot a factory sidemount, they can spot the difference between extractors and a turbo exhaust manifold. So your screwed anyway. Might as well not take the chance on damaging your motor as well.
But of course common sense says you've been waiting a fair amount of time already, might as well just wait that little bit more.
Running a car designed and fitted with an intercooler from factory without an intercooler is not clever, from both a logic and "thermodynamics" perspective.
Driving a turbo car on your P's is stupid, just wait until your fulls. Is stock R33 turbo power really that exciting that you'd risk lots of money and your licence for?.. No it really isn't.
My advise would be get a hi flowed turbo and bolt it together with the standard manifold..
Must better turbo and no worries with detonation and options to increase boost..
You can pick a good one up for around 1k give or take a couple hundred
I think the gate is 5psi but the solenoid bleeds it to 7 or something like that. R32 have 10psi gate spring.
you are correct
If you want to run no intercooler, best to go E85 or WMI
Rb30et had no intercooler standard and they didn't sht themselves.
If it used to be running a gt30, that would be harder on the motor than the little r33 7psi setup.
And they ran a stupid low compression ratio as part of the no intercooler package.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
