Hi Guys,
I've gone a slightly different route with boost control on low mounts and am using a pair of turbonetics 30326 dual port wastegates on my HKS2530s and a 4 port MAC valve to suit.
idea is I can run very low boost pressure in Mrs/valet mode (preload will only be around 7.5psi) but can wind in 26+psi on E85. also, having the 4 port solenoid will assist in keeping the gates clamped closed until the ECU says otherwise.
my options for the boost source for the solenoid (which is located on the passenger strut right beside the turbos) are:
1) Tap each turbo and join with a Y piece into the wastegate solenoid.
2) Tap into the intercooler piping just after the twin-turbo pipe (which has the splitter mod done)
3) Just use the signal from the intake manifold pre-throttle plates.
my considerations are: shorter hose length and closer to the turbos = better control. I figured the faster pressure response would be a good thing when the solenoid is directing pressure to the back of the actuators to keep them shut during spool
the idea is to obtain optimum boost control with agressive ramp-on.
inter cooler is a 120mm Greddy unit, so I'm not expecting significant pressure drop over it.
boost control is being done per gear, with the TPS% position generating a MAP target with an Ethanol content modifier. so 100% thottle may be 20psi on petrol but 27psi on E85.
that map target is then used in a target MAP vs RPM table that dictates the waste gate duty cycle to achieve pressure target. also under WOT conditions closed loop correction activates using PID control for minor corrections.
the ultimate would be to use two separate solenoids, one for each turbo with its own reference but you would need to monitor turbo speeds to make the most of it I think.
Edited by burn4005
The difference between 1&2 would be so small as to be unnoticeable so do whatever comes easiest out of those 2. The chances that either of them would offer you noticeably different control characteristic compared to sourcing it from the plenum are probably not much larger, but on the basis of paranoia simply rule out option 3 because it means more pipework.
  • 2 months later...
Hi mate, slightly off topic but have you actually got the twin port wastegates hooked up in the car currently? no clearance issues at all and bolt straight onto t25/t28 frame turbos with the stock bracket? i'm looking at doing the same thing ( running the 4 port solenoid) thanks!
luckily I had HKS actuators, and they are bolted to the bracket rather than welded on (I think the garrett ones are welded to the backet, so won't work):
nengun-240692-00-hks-hks_strengthened_ac
and the turbonetics ones also have the two bolts in the same place.
they went in with a fair bit of swearing, but only an hour or so work. the support rods on the HKS brackets are in the way when you're trying to get a ring spanner on the actuator bolts, but got there in the end. rear actuator ports point outwards, front actuator ports point inwards so they don't foul the intake piping.
you also need longer actuator rods.. i got mine from GCG. you need two of the 1/4 UNF thread 80mm actuator rods for them to reach the wastegate flapper.
4 1/2 turns of preload has them making 8psi on wastegate pressure alone.
making 14psi at around 40% duty on the mac valve, and they are VERY sensitive to duty cycle changes. only a few % here and there makes a few psi difference. had a few coil issues so didn't go any higher until that's sorted.
Edited by burn4005
  • 7 years later...
http://u.2.cf.nengun.com/240692/nengun-240692-00-hks-hks_strengthened_actuator_set_of_2-325c2db07c.jpg
http://uploads.tapatalk-cdn.com/20160405/2c2aa82fd400ccb163ff82bdacf6c524.jpg
http://uploads.tapatalk-cdn.com/20160405/3c6f3e736de6d6409f28df543840937e.jpg
Did you run the power cables for the mac valve to the other side of the car near the fusebox? Utilizing the stock boost controller cables? or did you run new ones?
it was 8 years ago who f**king knows
  • Haha 1
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
