While my Bora is in a million parts I've started looking for other stuff to fix.
I then leaned on a small piece of vacuum line and heard a crack and lots of airflow/sucking!
The brake booster vacuum line is brittle as hell and needs replacing. The two replacement hoses from VW are $300 so I thought I'd see if I can make my own up (car's not worth a lot, its not worth me getting OEM ones).
One end is apparently 13mm ID which could be a problem as I've only seen silicon line up to 6mm ID. This is the part that goes to a one way valve.
Can I use fuel line? Can I get some silicon line? Can I just fix the existing vacuum line somehow (cracks seem to be only around the ends of the line and not mid-way.) Looks like she's been in a bad way for quite some time and that I just made it worse.
Could I cause any probs by using non-exact hoses (ie larger or smaller ID)?
Is it easy to increase/reduse size of silicon lines?
Sanks.
https://www.sau.com.au/forums/topic/463951-diy-vacuum-lines-fuel-line-maybe/
I've used fuel line before as a bit of a "get me home" fix and may or may not have left it on my car for months on end :woot:
In my mind it's the most durable of the hoses on a car, shouldn't be any issue - $300 for a rubber hose is a joke hahah
Fair enough. on my R32 when i put the RB25 in i used a bit of silicon rad hose from the plenum to the brake booster to get the car running and didn't have any issues.
In saying that, I can see how fuel hose could possibly collapse under vaccum but you'd really need to give it a go
any hydraulic place has rubber hose with fibre reinforced line, guaranteed not to collapse. Take your hose to them and ask, if they are any good they will have a solution for under $50 and it would be permanent.
  • Like 1
Yeah nice idea. Theres a few Hydraulic places in Mona Vale and Brookvale I can check.
Considering the cracks are only around the barb fittings, is there a tape I can use in the meantime? The lines have heat protection on all the fittings as it goes behind the engine block.
Yep amalgamating tape..........get it at Jaycar and the like. As you stretch it it sets off a chemical reaction and binds together. Stretch it heaps, if you break it then back off a little bit lol.
It is not supposed to like degreaser, but I've used it and it seems ok, maybe if its sitting in it??
  • Like 1
And one last thing, when finishing off wrapping, just stretch the tape till it breaks. Keep your thumb on the work area and it should break under it and bond in to the work area, so no loose flapping tape like you get with insulation tape.
  • Like 1
Awesome, will do, thanks!
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
