Curious is its just double sided tape holding on all the plastic fender extensions as well as the same extensions on the door ? Thinking of taking them off so I gets cleaner look but worried there are holes behind them. Has anyone done this ? Cant seem to find threads for it.
https://www.sau.com.au/forums/topic/463952-removing-plastic-fender-extensions/
There are a number of plastic 'rivets' attached to the wheel-arch flares and side-skirts. These line up with plastic socket (sorry, I don't know the terminology) which are embedded in the car body. The rivets hold the flares to the car. You need a flathead screwdriver or similar to pop the rivet out, and there are screws under the sideskirts also. With the arch flares etc removed you will have a series of white plastic discs along your bodywork.
They could be removed I guess, but then you'll have holes.
  • Like 1
Yeah some of mine are falling off as the plastic clip bit has snapped from the overfender... need to work out if i can DIY spray it and reattach somehow...
If you find something that looks clean and durable, keep me updated ! ;)
