Jono.c Posted April 2, 2016 Share Posted April 2, 2016 (edited) Hey Guys, I have a S1 C34 Stagea with an RB25DET and AutoHas basic mods done (3" exhaust, 10psi, FMIC, Spitfires)Nistune does not offer an ecu for the S1 Stagea and most standalones can't control the auto properly so i've been looking at just running an e-manage piggyback.I'm just wondering what my limit would be with this ecu.. Am i able to run a slightly larger turbo, more boost and run a forward facing inlet manifold? Or can it only be used to tidy up the standard tune basically?Also does this get past r&r?Thanks Edited April 2, 2016 by Jono.c Link to comment https://www.sau.com.au/forums/topic/463967-e-manage-blue/ Share on other sites More sharing options...
KiwiRS4T Posted April 2, 2016 Share Posted April 2, 2016 Post in the Stagea section next time - plenty of people have tried the E-Manage. You can run an E-Manage, HKS F-Con or a proper ECU such as Link etc. but they are normally piggy-backed in to the stock loom. Best solution is a manual box. Why do you want a forward facing inlet manifold? You can run as big a turbo as you have supporting mods for - e.g. AFM, injectors , intercooler etc. Contact Hypergear for a deal on a better turbo that will bolt straight in and an Adaptronic? ECU. Link to comment https://www.sau.com.au/forums/topic/463967-e-manage-blue/#findComment-7705763 Share on other sites More sharing options...
Jono.c Posted April 2, 2016 Author Share Posted April 2, 2016 I don't want to manual swap it at this stage.I just wanna know the limit of the e-manage really.. how must boost i can run on it with a bigger turbo or if it just tidies up stock tune..Is r&r still apparent with emanage?I want to go ffim for better response and obvious benefit for servicing Link to comment https://www.sau.com.au/forums/topic/463967-e-manage-blue/#findComment-7705841 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 4, 2016 Share Posted April 4, 2016 better off getting an adaptronic and splicing into the loom, however direct all the injection/ignition points to the adaptronic. Also you can have idle control, etc. through the adaptronic as well as setup a dashpot/calm down effort as you go into gear. Link to comment https://www.sau.com.au/forums/topic/463967-e-manage-blue/#findComment-7706606 Share on other sites More sharing options...
Trex Posted April 4, 2016 Share Posted April 4, 2016 better off getting an adaptronic and splicing into the loom, however direct all the injection/ignition points to the adaptronic. Also you can have idle control, etc. through the adaptronic as well as setup a dashpot/calm down effort as you go into gear. as far as i am aware idle control isn't available with the auto. For me it isn't. whats dashpot and calm down effort? Link to comment https://www.sau.com.au/forums/topic/463967-e-manage-blue/#findComment-7706628 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 4, 2016 Share Posted April 4, 2016 with auto as you hit the brakes it needs to hold the revs a little bit before it idles or it will stall easily... also a great feature of adaptornic is you can use an input to detect when the car is in gear and up the revs. Link to comment https://www.sau.com.au/forums/topic/463967-e-manage-blue/#findComment-7706640 Share on other sites More sharing options...
Jono.c Posted April 4, 2016 Author Share Posted April 4, 2016 Im not trying to be rude but i just wanna know what i can do with an emanage haha Link to comment https://www.sau.com.au/forums/topic/463967-e-manage-blue/#findComment-7706712 Share on other sites More sharing options...
