Before biting me yes I posted in the maint section but no replies - and obviously this is an FI engine .
In the heater feed line that exits the rear of the block on the drivers side there is a four way steel junction tube . It has two other outlets to feed the oil heat exchanger and the small line that runs up/over the inlet manifold to the throttle body .
My mongrel has a pin hole leak just after the hose join on the TB line side .
Really need a new or good used one to make a reliable fix here . Also this is going to be a count of a job to remove and replace so only want to do it once . Sounds like on a hoist underneath with the starter motor out .
Luckily someone here in another thread posted the cooling system plumbing diagram and it shows this as part no 14075N which cross references to OEM Pn 1405321U00 .
So has anyone else had this drama and is this "Pipe Assembly , Heater Feed" possibly still available new ?
Car is a 96 GTS25T S2 btw .
Just what you want when the ID squirters were fitted and wanted to go tuning .
Any help much appreciated cheers Adrian .
You have the part number, Nissan is only a phone call away. Or wait and buy from Amayama for $25
If you only want to do it once and dont want to mess around, those are your 2 best options
https://www.amayama.com/en/search?currency=36&q=1405321u00
Edited by 89CAL
I spoke to John Robinson Nissan spares today and the part is on its way from Japan .
Also Nissan Import Spares has moved back to the old location next to Super Cheap on the south bound side of the Princes Hwy Rockdale in Sydney .
Cheers , A .
