I also have a sinco that was made for me and it was shipped to sydney and i can tell you the quality was amazing. Comp coatings said it was the best one that they have seen in a long time.
  • Like 1
Not having dig or anything but i have trying arrange a 6 boost to make me a manifold for over a month, replied to couple messages with price etc told me he would send his details through the next day but nothing 5 or so messages later nothing.
Sinco great customer service organized it within hour of messaging on a weekend
  • Like 2
  • 1 year later...
thought id revive this thread and share my experience with crg.  i have been following their work on fb and was impressed. so recently took delivery  of a twin scroll t4 rb25 and a 50mm gate($80 to weld the gate flange :(  . when ordered it took 1.5 weeks longer than expected, they dont answer phone calls and take a long time to reply to fb msges. once arrived wastegate had vacuum fittings already fitted which is strange. no box no CD. no instructions jus the foam insert.. took photos of the gate and sent to turbosmart to confirm if genuine. as crg wouldn't reply  and already sus on them. turbosmart replied and its the real deal. fitting the manifold tonight, 5 of the studs massively fouling on the pipe by atleast 15mm, had to cut down. lucky the engine is out and it would be very painful in. could barely turn the nut with a open end spanner. i understand its custom parts and some mods need to be made. also will have to redo my oil lines. anybody want to swap with a 6boost?.   photos to support this. i dont like to do this but somethinng needed to be done.
18 minutes ago, bilk06169 said:
ive got a female 4an right angle but that wont work. ill have to run banjo to 4an. btw during that time did get in touch with them and said they had machines down ....
machines down? or workers? Usually a lack in workmanship is due to stock which is metal, so no. Qualified workers who know what they're doing and care about, yes.
Yes the mani looks great, but thats all it will ever do if you cant fit fittings onto it..........................
Disgusting.
For what its worth i needed to use a banjo for the oil feed on my custom one at the top of the page. Also the stud at cyl 6 while not needing to be shorterend, isn't able to fit a bolt on so you kinda need to thread a bolt on with the manifold not sitting flush. Guess that'st he trade off. I presume that the CRG one is a size smaller pipe so a smaller radius etc so sits closer
So in summary, their customer relations/communications need improvement.
And for fitment you've needed to trim exhaust manifold stud length, be patient/dextrous with a spanner, and use a more creative means to plumb the oil supply.
As per Peter's comments ^^ the fitment issues are fairly common, and most people experience these things.  They are less concerning than getting good clearance/fitment for the dump pipe and WG plumb back; not to mention the compressor plumbing.  Modifications usually involve a problem solving mindset, and perseverance.
Hopefully the setup works well once it's all done.  What turbo are you using?
petes manifold is a much better design. anyways i do understand all the modifications and changes etc. but the manifold isnt even in the car yet and its not up to my standards. what is concerning is that a jig should be setup as they probably made over 1000 rb manifolds, why arnt they constantly making  improvements and getting customer feedback too. that's what i would be doing if i ran a business.
pipe size is 1 1/4 "   --    ( should have gone bigger)
ill be fitting a 6466 precision --- im still up the air about the rear housing, whether to use 1.00 or .84 split ??? built rb25 neo for street duties .272 cams
I got Rex Kelway to make a manifold for my setup, easy to deal with, reply's normally within an hour or 2, yet always within a day. Awesome work too, cant fault mine, ill see if i can dig some pics up later
I had issues with my 6boost last year,
ordered a 6boost gt42 manifold for my r32 gtr, my turbo was sitting so high the bonnet wouldn't close
rang them up and said they sent just the normal 6boost manifold, guessing for smaller frame turbos,
received a second one, exact same issues
ended up with a custom turbo-1 manifold in t4 with twin 38mm tial gates that clears everything, AC lines didn't need moving or anything and turbo sits in a good spot
So who made the custom one then?  Pics please!
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
