Hi i have finally about to start my motor but im crippled because i need a frew fittings for my defi oil pressure and oil temp gauge. I have a rb26 grex oil relocation kit and on the side it has to slots i believe one is NPT but i could be wrong. The other is way to big for the sensor. Seems like an adapter fitting needs to go in there. 9c8f03691d103c7583fc599c8f0a9249.jpg106f0ee5e2b25c67b06e03b715134a7b.jpg
So yes, there should be a small gold coloured adaptor which goes in the larger hole to space it down for a 1/8 npt fitting, part number 16400519
Here is a few listings for those fittings.
http://www.nengun.com/greddy/oil-sensor-adapter
Hope that's enough to point you in the right direction!
Edited by Jordy32
There was a recent discussion on here about the stupidity of Japanese pipe thread specifications. It is important not to assume that "PT" mean "NPT".
From Engineering Toolbox
Japanese Standards PF - JIS Parallel Pipe Threads
PF threads are functionally interchangeable with BSPP. This is an old designations replaced with G.
Applicable Standards
  • JIS B 202 PARALLEL PIPE THREADS
  • ISO 228/1 PIPE THREADS PT 1: DESIGNATION, DIMENSIONS, TOLERANCE
PT - JIS Taper Pipe Threads
PT threads are functionally interchangeable with BSPT threads. This is an old designations replaced with and R and Rc.
  • JIS B 0203 TAPER PIPE THREADS
  • ISO 7/1 PIPE THREADS: DESIGNATION, DIMENSIONS/TOLERANCES
PS - JIS Parallel Internal Pipe Threads (to mate with PT threads)
More about pipe thread standards.
Thanks i have it ordered. Does anyone know if the defi sensors are all the same from the advance bf gauges to the older link bf gauges. I have the gauge (old bf) but no sensor??
I have these on my Greddy thermostat plate at the block and they required drilling and tapping. I used 1/8" NPT for one to TEE into my factory oil pressure sender, and added a hose attachment for the Haltech oil pressure sensor hose since they instruct you to relocate them. On the other one it is tapped M12x1.5 for my GM oil temp sensor which is an ATI to my Haltech platinum pro plug-in. Haltech recommends remotely locating the pressure sensor.
The GM fitting was M12x1.5, the haltech hose was JIC (or -3 AN) on one side and 1/8" NPT on the other for the sensor.
My stock oil TEMP gauge will no longer work at the expense of me having the Haltech read this constantly and I will be able to set my tune up with their "ENGINE PROTECTION" portion which will allow me to put safeguards in for low oil pressure and/or high oil temps (reduced boost, reduced RPM, check-engine light ON, etc). Which will be more useful to me than a gauge. The final idea being that I will use their GAUGE ART box to display my custom gauge information on a VGA screen in the dash later.
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
