Hi i have finally about to start my motor but im crippled because i need a frew fittings for my defi oil pressure and oil temp gauge. I have a rb26 grex oil relocation kit and on the side it has to slots i believe one is NPT but i could be wrong. The other is way to big for the sensor. Seems like an adapter fitting needs to go in there. 9c8f03691d103c7583fc599c8f0a9249.jpg106f0ee5e2b25c67b06e03b715134a7b.jpg
So yes, there should be a small gold coloured adaptor which goes in the larger hole to space it down for a 1/8 npt fitting, part number 16400519
Here is a few listings for those fittings.
http://www.nengun.com/greddy/oil-sensor-adapter
Hope that's enough to point you in the right direction!
Edited by Jordy32
There was a recent discussion on here about the stupidity of Japanese pipe thread specifications. It is important not to assume that "PT" mean "NPT".
From Engineering Toolbox
Japanese Standards PF - JIS Parallel Pipe Threads
PF threads are functionally interchangeable with BSPP. This is an old designations replaced with G.
Applicable Standards
  • JIS B 202 PARALLEL PIPE THREADS
  • ISO 228/1 PIPE THREADS PT 1: DESIGNATION, DIMENSIONS, TOLERANCE
PT - JIS Taper Pipe Threads
PT threads are functionally interchangeable with BSPT threads. This is an old designations replaced with and R and Rc.
  • JIS B 0203 TAPER PIPE THREADS
  • ISO 7/1 PIPE THREADS: DESIGNATION, DIMENSIONS/TOLERANCES
PS - JIS Parallel Internal Pipe Threads (to mate with PT threads)
More about pipe thread standards.
Thanks i have it ordered. Does anyone know if the defi sensors are all the same from the advance bf gauges to the older link bf gauges. I have the gauge (old bf) but no sensor??
I have these on my Greddy thermostat plate at the block and they required drilling and tapping. I used 1/8" NPT for one to TEE into my factory oil pressure sender, and added a hose attachment for the Haltech oil pressure sensor hose since they instruct you to relocate them. On the other one it is tapped M12x1.5 for my GM oil temp sensor which is an ATI to my Haltech platinum pro plug-in. Haltech recommends remotely locating the pressure sensor.
The GM fitting was M12x1.5, the haltech hose was JIC (or -3 AN) on one side and 1/8" NPT on the other for the sensor.
My stock oil TEMP gauge will no longer work at the expense of me having the Haltech read this constantly and I will be able to set my tune up with their "ENGINE PROTECTION" portion which will allow me to put safeguards in for low oil pressure and/or high oil temps (reduced boost, reduced RPM, check-engine light ON, etc). Which will be more useful to me than a gauge. The final idea being that I will use their GAUGE ART box to display my custom gauge information on a VGA screen in the dash later.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
