hi guys and girls i have a highmount setup to suit rb engines. This is a complete kit pulled out of freshly built motor. Was basically run in and never made it to power tune by the previous owner of the vechile. I wish to go in a different direction.
this is a direct bolt in kit with just about everything you will need hot side wise
kit includes
- gt3572rl ball bearing original garrett turbo. .82 rear t3. Feels to be some normal shaft play. There are some small superficial chips on the blades. I dont think it will effect operation much however if you feel its an issue i got quoted 300 for a brand new comp wheel or 450 to upgrade it to a gtx billet wheel for that extra spool action ?
- high mount manifold with a 45mm gate port
-45mm turbosmart hypergate
-braided oil line and also water lines included. Basically all lines and high quality fittings included. oil drain line will need a new section of hose which is about 20cm.
-custom made dump pipe 4 bolt flange plumb back gate. can be easily modified for screamer if your that way inclined. high flow cat and 2 bolt flange l on at exhaust end
-intake pipe and filter
kit has been removed and ready for collection.
any questions please call or text 0410616101
rb25det rb30 rb2530 rb2630 rb26 skyline gtst gtt
