Hey guys
My setup basically is a forged bottom end rb25det, only thing standard is the head (no porting) . I have aftermarket springs and 268 cams.
Have a plazmaman ffp, 6boost high mount with a proboost gtx3582 with a .82 strapped on ( same spec as garrett) .1200cc injectors and dual walbro 460 pumps.
Now when it comes to tuning most tuners reckon my current power level (415rwkw) is near the point the turbo maxes out. Is there truth comparison wise to other people using these turbos.
My aim was roughly the high 400 mark but after hearing I may need a turbo upgrade I've decided to bump the power I'm going for.
How would a borgwarner s366 and s369mm spool up on a 2.5? Or even a gt42 ? I don't care if the car comes on full song around 5ish k.
https://www.sau.com.au/forums/topic/464053-66-69mm-turbos-rb25det/
Can confirm it's not maxxed out on the turbo side at least. I have about the same power on a .82 through an Auto at 23psi. Some people will run 35psi and make well over 500 with them so I doubt the turbo is the restricting factor here if you're willing to lean on it.
1.06 probably will help, depending on the rest of the setup will kind of determine how much you can get out of the turbo, but the turbo itself probably doesn't need to be changed but something bigger may bandaid the problem.
The borg warners are good stuff, and better in many areas but it appears that as far as Garretts go, the GTX3582 is the 'good' one of the range and holds its own compared to alternatives with Precision and BW. For high 400's then man you have the right turbo already on the car.
Thanks for the reply guys.
Yeh that's what I was thinking. I done my research when it came to getting the turbo but now come tune time the tuners are throwing doubts in my head.
Restriction exhaust flow wise it's basically a 3inch dump to a straight through 3.5 exhaust
I was thinking of going the 1.06 but that will probably make it lag as much as a bigger turbo itself with a matched housing.
Edited by Gta51
bigger compressor will lag more, is your setup twin scroll?
If you're making that kind of power and want more with the larger rear housing.. probably best to dump both gates into the atmosphere and run the 3.5" exhaust.. if not, time for a 4" system.
i will bet the last line you posted is correct aswell...those 1.06 housings are good for killing backpressure in bigger motors, like 4.0 barras.
the turbine hardly flows any more on a 3.0 with one..and the lag sacrifice is ridicilous..fine if your auto..manual not so much
cheers
darren
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
