  • 4 weeks later...
I suppose I should mention that my budget has changed slightly and with it, my goals. Chasing closer to 700hp on e85 and still 600 on 98. But have decided to go for a single. I'm getting hassled in my F6 and that's stock.
getting hassled in a stock car is pretty low. I got RBT couple days ago and cop couldn't give two shits, looked at my car couldn't see it sitting on the ground making a heap of noise just a little quiet brap in the exhaust but nothing noisy then let me go (respect is important) I was hoping he popped my bonnet tho. It would have been the first standard GT-R engine bay the guy probably would have ever seen Lol
  • Like 1
I own an f6 sedan. It is completely stock. Even has a baby seat. I still get pulled for a random check. Must be the area. Can't wait to put the baby seat in a 700hp+ GTR.
Get it engineered, don't drive like a dick on the roads, and don't act like a bogan or hektic flamin mongrel and problem solved.
People worrying about defects is so 2007.
  • Like 1
In WA, a few years back there was this massive cleansing of all things modified. We had a number of dodgy "tuners" and so there were lots of questionable cars. Plus there was the fast and the furious factor. So police picked on anything that had a loud exhaust.
My problem is I live in the hills. There are lots of long straight back roads and lots of twisty ones to. People come up constantly test there cars. So police stop fast cars regularly. I'll get mine engineered and pitted. As for driving, I make no guarantees.
  • Like 1
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
