Hey all
currently in my track car have a rb25
360kws (graph below)
Mods
HTA3076R turbo with .82
Trail wastegate
dump and screamer
6 boost manifold
G4+ link computer
plazamaman Plenum
Yellow jackets
1000cc injectors on plazaman rail
Decent fuel set up
E85
Im thinking about bolting it all onto a rb30 i have thats in good nic.
will give the block a clean up, put new head studs etc with it.
is it worth going to the trouble? Whats gains would you think id see?
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/
More torque, more power.
Frankly I wouldn't bother until your engine blows.
I was assuming that your track car was AWD which means an adapter plate but if its 2wd it not so hard.
You are making good power for a 3076 and to get the most out of a 3L block you might need a bigger turbo (maybe not).
But if you are keen by all means go ahead - you will go faster!
  • Like 1
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708257
Shaun is highly experienced with the entire RB engine range so it would come as a surprise if he hadn't identified VCT wasn't triggering. But stranger things have happened.
I drop by the workshop most Friday's, I'll ask him about your car tomorrow if you'd like?
As for your original question, it is a no brainer... yes to the RB30 option every time!
Here's my HTA3586 .85 RB30 25DET @ 22psi on the same dyno:
Same ECU and plenum too.
Your RB25DET is producing approx' 85kW at the wheels at 3700rpm vs. my RB2530DET 180+kW
At 4400rpm 135kW vs 330+.
Car goes back on the dyno Tues to complete the tune - yet to add timing and still rich up top - and wind boost up (~30psi)
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708349
Yep if you're going to pull the engine out definitely go the 30.
Here's my power curve with the 30 - less top end than yours but more power early and that's with a 3582 turbo (NB the torque curve - not so much the numbers - they mean nothing to me but more the shape of the curve and early peak torque):
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708376
No problem at all mate, happy to help out. He is no doubt flat-out preparing Terry's yellow RX2 (630kW rear wheel craziness!) for the ANDRA Finals this weekend but I'm sure I can squeeze in a brief chat.
That's the spirit! [emoji4][emoji106] It is well worth the effort and expense. You won't regret it.
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708382
Im doing exactly this but building a forged rb30 with a spare head whilst keeping the current 25 rolling. Ill swap my cams, turbo, exhaust manifold oil and water pumps across before dropping the 30 in.
Using four different RB's to create something unique:
Rb30 bottom end
Rb25 head
GTR intake
GTSR exhaust manifold
<3 the dirty 30
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708468
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
