Hey all
currently in my track car have a rb25
360kws (graph below)
Mods
HTA3076R turbo with .82
Trail wastegate
dump and screamer
6 boost manifold
G4+ link computer
plazamaman Plenum
Yellow jackets
1000cc injectors on plazaman rail
Decent fuel set up
E85
Im thinking about bolting it all onto a rb30 i have thats in good nic.
will give the block a clean up, put new head studs etc with it.
is it worth going to the trouble? Whats gains would you think id see?
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/
More torque, more power.
Frankly I wouldn't bother until your engine blows.
I was assuming that your track car was AWD which means an adapter plate but if its 2wd it not so hard.
You are making good power for a 3076 and to get the most out of a 3L block you might need a bigger turbo (maybe not).
But if you are keen by all means go ahead - you will go faster!
  • Like 1
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708257
Shaun is highly experienced with the entire RB engine range so it would come as a surprise if he hadn't identified VCT wasn't triggering. But stranger things have happened.
I drop by the workshop most Friday's, I'll ask him about your car tomorrow if you'd like?
As for your original question, it is a no brainer... yes to the RB30 option every time!
Here's my HTA3586 .85 RB30 25DET @ 22psi on the same dyno:
Same ECU and plenum too.
Your RB25DET is producing approx' 85kW at the wheels at 3700rpm vs. my RB2530DET 180+kW
At 4400rpm 135kW vs 330+.
Car goes back on the dyno Tues to complete the tune - yet to add timing and still rich up top - and wind boost up (~30psi)
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708349
Yep if you're going to pull the engine out definitely go the 30.
Here's my power curve with the 30 - less top end than yours but more power early and that's with a 3582 turbo (NB the torque curve - not so much the numbers - they mean nothing to me but more the shape of the curve and early peak torque):
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708376
No problem at all mate, happy to help out. He is no doubt flat-out preparing Terry's yellow RX2 (630kW rear wheel craziness!) for the ANDRA Finals this weekend but I'm sure I can squeeze in a brief chat.
That's the spirit! [emoji4][emoji106] It is well worth the effort and expense. You won't regret it.
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708382
Im doing exactly this but building a forged rb30 with a spare head whilst keeping the current 25 rolling. Ill swap my cams, turbo, exhaust manifold oil and water pumps across before dropping the 30 in.
Using four different RB's to create something unique:
Rb30 bottom end
Rb25 head
GTR intake
GTSR exhaust manifold
<3 the dirty 30
https://www.sau.com.au/forums/topic/464090-rb25-vs-2530/#findComment-7708468
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
