Got told on FB group regarding this query, got told that nissan spark plugs are: PLFR5A-11
Can anyone confirm this is OEM?
Seems to be decently priced aswell
http://www.ebay.com.au/itm/6-x-Genuine-Spark-Plugs-For-NISSAN-PLFR5A-11-OR-22401-5M015-/222058100259?hash=item33b3b1b623%3Ag%3At7AAAOSwezVWzClK
Get yourself a copy of the 2007 g35 service manual - its listed in there.
The plugs you listed are 2 full steps hotter then OEM - Be careful.
I buy lots of things online, one I don't recommend is spark plugs. Received some once knocked up and in bad shape - had to send back.
Edited by Rufus007
Went onto the NGK website and found compatible spark plugs for the 350Z VQ35HR (same engine) and they recommended DF7H-11B, repco also recommended the same ones
Found some other link which stated LFR5AIX-11.
Still unsure which ones to purchase
  • 1 year later...
Bump for this thread.  We have a 3.5L 2007 v36 sedan skyline and looking for spark plugs
DE is regular and HR is direct injection (350z with VQ35HR)
Went to autobahn and there were two options NGK LFR5AIX-11 Irridium @ $25 each lasts 60k and Platinum PLFR5A-11 @ $33 each rated for 100k.  That last plug was to suit 03-07 Nissan 350Z.
Not sure which plug to go for ?
Cheaper one.
You will  probably sell the car before you need plugs again. That's what my crystal ball is telling me.
Otherwise the plug is the same gap and heat range . There is absolutely no way you would notice the difference.
  • Like 1
HR is not direct injected.
The direct injected engines end with a DD.  for example VQ30DD, VR30DDTT, MR16DDT, etc
Edited by sonicii
  • Like 1
20 hours ago, Ben C34 said:
Cheaper one.
thanks for the reply - so both are correct fitting options ? Either would work ?  thanks
  • 1 month later...
On 4/7/2016 at 9:15 PM, Rufus007 said:
Factory OEM for vq35hr are Iridium - Denso FXE22HR11. Got mine from Nissan, they were $34 each though. Maintenance schedule on these is 170,000km but I recommend replacing earlier.
Confirmation from Fast....
The PL and I guess the LF are for the DE engine which hav different plugs to the HR.
If for the HR motor I would be heading towards the DF7H-11B,  myself.
  • Like 1
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
