R32 Skyline Parts. Qld, Will Post. Do Luck Front Bar, Nismo Rims, Apexi N1 Coilovers, New Nissan Items, Aftermarket Mirrors Etc
My R32 Skyline has now been sold so its time to get rid of the parts floating around and get started on the 260z build.
All items located in Mount Warren Park, QLD but willing to post at buyers expense.
1: Aftermarket electric mirrors (non folding). Has R32 base plate and I'm pretty sure R33 base plates as well. Will need new paint job. $150
2: R32 GTR bonnet latch area, Perfect for the GTST owner putting a GTR bonnet on. $80
3: R32 blank Nissan key (suits all R32's) (sold)
4: R32 GTST stock blow off valve $20
5: R32 GTR new top and bottom door hinges (both sides) so you help stop sagging doors. $100
6: R32 Cluster back and clear plastic $20
7: R32 Headlights (only good for parts or swapping your stuff onto them) $120 a pair.
8: R32 drivers side kick panel $30
9: R32 glove box $50
10: R32 fuel sender $40
11: Fake HKS blow off valve with adaptor for stock location on R32 GTST. $60
12: ARC intake pipe for R32 GTR (no bov) $50
13: Apexi N1 coilovers for R32 GTST. Think 1 is leaking. $500
14: R32 Cat $50
15: R32 GTST Radiator (unknown condition) $30
16: RB20 turbo, dump and front pipe. Think it's a r34 actuator (unsure) plus the random crap in the box $150
17: R32 door trims $80 a pair front or rear
18: Nismo LMGT3 5x114.3 17x7 +30 and 17x8 +38. Good Toyo proxie R888 on front and T1R on rear. $1800 also comes with 3 spare valve stems.
19: RB20 Cometic exhaust manifold gasket (New) (sold)
20: R32 GTST Do Luck style front bar. Been cut to fit around cooler pipes and front mount. New but only trial fitted for checking cuts around piping etc. $300
Images located on Photo bucket: http://s1243.photobucket.com/user/Triptych69/library/R32%20Skyline%20Parts
2: R32 GTR bonnet latch area, Perfect for the GTST owner putting a GTR bonnet on. $80 (Sold Pending Payment)
5: R32 GTR new top and bottom door hinges (both sides) so you help stop sagging doors. $100 (Sold)
    • Should be close enough. Noting that 88Nm is equivalent to 2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there.
    • Cant find a torque spec in the R32 gtr manual  But there is one in the silvia manual Not sure if it's the same
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
