Power fc suit rb25det neo manual, no hand controller - $800 firm
D1 stable rb25 t4 split pulse exhaust manifold with 2 bolt flange for external gate, new - $500
rb25det (s2 i believe) blue silicone coolant hoses, should be direct fit, new - $100
Adjustable camber arms front (brand - tasautosport), did 1000kms on the car, only removed for upgrade - $100
Adjustable camber arms rear
Rear hicas elimination kit/drag rod kit
(brand - tasautosport), did 1000kms on the car, only removed for upgrade, completely removes hicas - $100
Q45 afm, was working when removed, has plug and wires - $150
R34 coupe boot (gv1), avg condition, suit drift pig - $20
R34 stock suspension, good condition, boots a little worn - $200
R34 front stock suspension, good cond, - $100
R34 HICAS system, working when removed - $100
R34 stock front and rear camber arms - $100
2 x 17x7.5 territory stockies, hold air fine, could use paint, tyres chopped - $50
rb25det s2/neo adjustable cam ring gear (adjust intake cam gear few degrees whilst retaining VCT, good for dialing in cams or rb30det), new, 5 left, comes with mounting hardware - $50
Some prices neg, if you want pics just ask. Will post at buyers expense.
Pickup Willetton (SOTR). Text if you want - o4o4 three98 four19
Edited by sleptema
