Hey all,
Im trying to install the steering wheel controls and ive connected the 12v wire for the LEDs. The 3 wires that come out the back of the clock spring i have the following questions.
1. To these wires come out behind the stereo to connect to or should i cut them at the clock spring.
2. The sony control plug has red, white& black wires but the clock spring has red, yellow & green. Does it matter what colours i attach to to allow the steering wheels to fuction properly and does anyone have a match up guide for this.
https://www.sau.com.au/forums/topic/464139-mv35-steering-wheel-audio-controls/
Hey all,
id say as a mass produced car with many options. one loom was made with many connectors for the many options available. cost/time. will be following as i have steering wheel controls that come to plug behind stereo just cant get them to work with my head unit
Ok so think i have worked it all out
Black - Yellow (earth)
Red - Green (imput 2)
White - Red (input 1) green in picture
That looks right from what I recall, as long as your head unit can handle resistive controls and you can teach it what the buttons do you're all good. If not you'll need an Axxess ASWC-1 or PAC SWI etc.. adaptor. I grabbed an ASWC-1 when i was going to drop a single DIN cheapy in but ended up going a different route.
  • Like 1
Cheers mate. I saw that the other day but with mine being a double din i may not need that control box. Once i get a break from the long work hours/daddy duties ill know a little more. Ill take alot of photos throughout the process for a quick writeup with double din (sony) for future installs.
Edited by joshm35
  • Like 2
Ok. I have found my error. I cut one of the unit control sensors (white) instead of a led earth (pink) as per commsman's write up as my unit did not have this wire. I have recently added in a wire to earth it out. I have tested once i discoverd and corrected the issue and it works with my sony double din without the control box as per last post. So here are some pictures for reference. (No i will not be leaving the wiring like that.... it was to test. 90dbd6e1ddcffd7acd14b1a2945e2464.jpg7334c43d2567627aecd017003b9cbe07.jpgb2b9f4aff0729dac6edda2f24fba0485.jpg5b10fe5874788de19bdaf8ab64a22762.jpg5a7a603ac8a5d88a964862caca7be883.jpg
Good to see you have it figured out
That might be what i need to do with mine. As soon as i would plug connector in back of stereo it would turn off. I have an earth wire just floating about. I really dont want to be pulling all the car apart again done it 5 times since purchase haha
The plug is there. Mine was taped to the main harness out of the way. The yellow wire is the earth as per previous posts. Turns out my 2 units are not LED but as i have it working im not too fussed.
Edited by joshm35
  • Like 1
im still confused lol.... Would love a write up on how you sorted it all out mate and to add job well done bro! [emoji106]
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
