Ok i hope this makes sence for your future installs. This was installed onto a sony xav65.
1. Remove the lower steering column to access the lower clock spring plugs. Make sure that the wires are there as per photo
2. Remove all interior panels to access the rear of the stereo wiring. Locate the main harness and you will find the plug that contains the steering wheel harness as shown in the photo below
3. Cut the yellow (earth) , red (input 1) & green (input 2). Connect the sony plug as per the following
Black to yellow (earth)
White to red (input 1)
Red to Green (input 2)
4. Go into the stereos settings and press the associated buttons to what your device is asking for to set the steering controls.
5. Wire up everything properly (i soldered and heat shrinked all wiring). Put the car back to gether once complete.
note. If you are installing a new unit onto your car i can post a how to if required. If you have a LED unit you can gollow the link in the last post that Commsman wrote up of how to wire up the power and earth. Hope this makes it easier to understand.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
