Hi all
I'm in the progress of buying locally or importing an M35 Stagea so i thought i'd like to see what options did your M35 come with?
Yes i'm aware there was a thread like this but that was back in 2009 http://www.sau.com.au/forums/topic/266710-what-options-did-your-m35-come-with/ , it's now 2016 and i'm sure there are a lot more M35 in the country by now.
I'd really like one with Aero kit, twin sunroof and everything else is a bonus. I know they're hard to come by so if i must, i will settle with just the Aero kit.
Attached photo is what's commonly listed on http://www.goo-net-exchange.com/ although some of the options mentioned in 2009 thread is not even listed there!?%$#
Thank you
PNM35
Factory options:
Aero kit
Dual sunroof
Cold pack
Viscous LSD
Sat Nav w/ reversing camera
Front corner cameras
"Comfort Package" which seems to include a Sat-based DJ service
Intelligent key and immobiliser
Aftermarket:
Cruise control
Bilstein struts
K&N pod filter w/ heat shield
Nismo exhaust (since sold)
OX rear under body brace (since sold)
Non-OX mid under body braces (unknown workshop name)
Earthing kit (one i have not seen before, may have been custom by the previous owner)
Under body air deflector
If you are looking at buying one, you can always go to http://nissan.epc-data.com and enter the VIN to view the factory options.
Edited by iamhe77
  • Like 1
PNM35
Factory options:
Aero kit
Dual sunroof
Cold pack
Viscous LSD
Aftermarket:
Cruise control
Bilstein struts
Holysh*t that's a nice list, where about in S/E melb as i'm as well, maybe you can take us for a spin sometime :).
My m35 had the following
Full aero kit (a lot only have some parts of the kit as each part could be ordered separately)
Leather seats
Dual sun roof
Heated windscreen to melt the ice off the wipers
Remote start
Factory lowered springs
Factory floor mats :)
Leather seats
Dual sun roof
Remote start
Remote start, factory? That's crazy. Well you can use the heated windscreen to melt the bird's drop off :).
250t rs four
Aero selection front bumper with fogs
Aero selection weather sheilds
Aero selection floor mats
Factory steering wheel controls for audio and cruise control.
Bilstein suspension.
Leather seats
Dual sun roof
Remote start
Racecars have no time for sunroofs
PNM35, I got the lightweight racecar spec:
- Sunroof delete
- Aero kit delete
- HICAS delete
- Cold pack
- Comfort pack
- Intelligent key
What's Comfort pack and Cold pack (bigger alternator)? Been searching auction sites in Japan and use the Fast software to see what's available/equipped in the cars that i'm interested in.
STDVS - COLD2
Leather seats
Dual sun roof
Remote start
Selling?
I'm after one with aero, twin sunroof, leather seat .... found one but the turbo is making loud noise :(!
Selling?
If it's a tidy car, use the noisy turbo as a bargaining tool, and budget for a replacement in the near future.
They all fail eventually.
  • Like 1
Mine also got the dipping mirrors when reversing, not a major option, but I find it quite nice!
i have one of this "dipping mirrors" control unit, but i found the left mirror can't back to original position after put knob from R to P,N,D. :woot::woot::woot::woot:
so i removed the fuse from that control unit.
Edited by YangLIU
Or you could just press the little bitton near your knees to stop it. So much easier..... just sayin
I don't actually know, I just saw I had them when I looked up my chassis code. :blush:
Cold pack has a couple of things.
Rear fog light replacing one reverse light
Heated windscreen to remove ice
Maybe more but those are for sure
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
