Hi all
I'm in the progress of buying locally or importing an M35 Stagea so i thought i'd like to see what options did your M35 come with?
Yes i'm aware there was a thread like this but that was back in 2009 http://www.sau.com.au/forums/topic/266710-what-options-did-your-m35-come-with/ , it's now 2016 and i'm sure there are a lot more M35 in the country by now.
I'd really like one with Aero kit, twin sunroof and everything else is a bonus. I know they're hard to come by so if i must, i will settle with just the Aero kit.
Attached photo is what's commonly listed on http://www.goo-net-exchange.com/ although some of the options mentioned in 2009 thread is not even listed there!?%$#
Thank you
PNM35
Factory options:
Aero kit
Dual sunroof
Cold pack
Viscous LSD
Sat Nav w/ reversing camera
Front corner cameras
"Comfort Package" which seems to include a Sat-based DJ service
Intelligent key and immobiliser
Aftermarket:
Cruise control
Bilstein struts
K&N pod filter w/ heat shield
Nismo exhaust (since sold)
OX rear under body brace (since sold)
Non-OX mid under body braces (unknown workshop name)
Earthing kit (one i have not seen before, may have been custom by the previous owner)
Under body air deflector
If you are looking at buying one, you can always go to http://nissan.epc-data.com and enter the VIN to view the factory options.
Edited by iamhe77
  • Like 1
PNM35
Factory options:
Aero kit
Dual sunroof
Cold pack
Viscous LSD
Aftermarket:
Cruise control
Bilstein struts
Holysh*t that's a nice list, where about in S/E melb as i'm as well, maybe you can take us for a spin sometime :).
My m35 had the following
Full aero kit (a lot only have some parts of the kit as each part could be ordered separately)
Leather seats
Dual sun roof
Heated windscreen to melt the ice off the wipers
Remote start
Factory lowered springs
Factory floor mats :)
Leather seats
Dual sun roof
Remote start
Remote start, factory? That's crazy. Well you can use the heated windscreen to melt the bird's drop off :).
250t rs four
Aero selection front bumper with fogs
Aero selection weather sheilds
Aero selection floor mats
Factory steering wheel controls for audio and cruise control.
Bilstein suspension.
Leather seats
Dual sun roof
Remote start
Racecars have no time for sunroofs
PNM35, I got the lightweight racecar spec:
- Sunroof delete
- Aero kit delete
- HICAS delete
- Cold pack
- Comfort pack
- Intelligent key
What's Comfort pack and Cold pack (bigger alternator)? Been searching auction sites in Japan and use the Fast software to see what's available/equipped in the cars that i'm interested in.
STDVS - COLD2
Leather seats
Dual sun roof
Remote start
Selling?
I'm after one with aero, twin sunroof, leather seat .... found one but the turbo is making loud noise :(!
Selling?
If it's a tidy car, use the noisy turbo as a bargaining tool, and budget for a replacement in the near future.
They all fail eventually.
  • Like 1
Mine also got the dipping mirrors when reversing, not a major option, but I find it quite nice!
i have one of this "dipping mirrors" control unit, but i found the left mirror can't back to original position after put knob from R to P,N,D. :woot::woot::woot::woot:
so i removed the fuse from that control unit.
Edited by YangLIU
Or you could just press the little bitton near your knees to stop it. So much easier..... just sayin
I don't actually know, I just saw I had them when I looked up my chassis code. :blush:
Cold pack has a couple of things.
Rear fog light replacing one reverse light
Heated windscreen to remove ice
Maybe more but those are for sure
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
