I've had a Vipec V44 plug-in on my Stagea 260RS since 2008. I recently changed my timing belt and set the CAS back to roughly the same position. The car has been driving fine. The other day I checked the timing and discovered it was 10 degrees over advanced, so I retarded it by 10 degrees after double-checking with a different timing light. Now the car drives worse than before. It hesitates coming on boost and makes much less power. I removed the top timing belt cover and confirmed the cam pulleys were correctly lined up with TDC. I also confirmed the cam half-moon shaped key for the CAS is still in position and hasn't broken off. So I'm at a bit of a loss as to where this 10 degrees of offset may have come from. Does anyone have any ideas?
Oh yeah, in setting the timing, I upgraded my firmware. I think I was about 4 or 5 versions behind the current release. Would this have caused any issues? In the base timing adjustment screen, the original offset (for 10 degree ref) was -82, as set by the Vipec tuner. Now it is -96 for the timing to be right. Do either of these numbers sound about right for an RB26?
One other thing, I did change the timing belt somewhere around 2008-2009 after the Vipec install and tune. I went back to the workshop and they checked the timing and adjusted the offset from -80 to -82. I was wondering in my head if the timing belt was always off by 1 tooth, but the fact I've changed the belt once already and it made minimal difference to timing, makes me think the possibilities are very slim.
Any ideas? I'm at a bit of a loss.
https://www.sau.com.au/forums/topic/464164-rb26-base-timing-woes/
My thoughts are there was possibly a timing correction built into the tune that may have been lost when the firmware was updated?
Isn't the timing offset just for the ECU to know where TDC is, not actually for setting the timing? I'm pretty sure that's the case with Haltechs but could be wrong. Worth investigating though.
Have you tried adjusting timing via the CAS as opposed to through the ECU?
Thanks for your reply mate. I actually took a save of the ECU tune after it was initially dyno'd in 2008. You can see the timing offset factor was -80 back then. I think the tuner changed it to -82 when I visited him in 2008/9 after I changed the timing belt the first time and he set the timing. On the weekend I initially adjusted timing by rotating the CAS. It ended up nearly at the limits of its adjustment, when it was centralised before the timing belt job. That's what raised the alarm to me. I think I had done the firmware update just before checking the timing.
Solved it! The old timing loop problems strike again. I found a bit of ignition lead and connected it between the coil and spark plug, then set the timing off that. Believe it or not, it was 9 degrees off! Previously I had tested the timing loop on the little timing wire loop at the back of the engine, as well as on the low voltage wires on the back of the coil. Both of these gave identical readings. Nissan must have some fancy timing light or something. I'm pretty sure the Vipec mechanic used the low voltage wires on the back of the coil, but maybe he had a better timing light than mine.
The car is doing damn well now. Very happy. Thanks for your help guys.
  • Like 1
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
