Hello
I am running a 400x260x70 sized return flow intercooler on my rb20 which has a rb25 turbo, tune, full exhaust, intake, gtr fuel pump.
I am upgrading to a larger fmic. I am deciding between a Blitz return flow fmic which is 600x266x76 or a regular fmic which is 600x300x100(or 70 maybe)
I've read many articles about intercoolers and response and so on. There seems to be no real answers I can find.
What are peoples results with return flow FMIC vs regular fmic in regards to response here on the forums.? Does it really matter that much? I am thinking that maybe it wont be that much difference.
Edited by yoshiii335
https://www.sau.com.au/forums/topic/464173-questions-about-fmic-and-response/
Shorter piping will make more difference than being return or not. So if you combine it with a ffp it might matter but otherwise not noticeably. Provided you have suitable components. Of specific situation yields different results such as turbo size and power level etc.
You will not notice any difference in response. The path the pipework takes to and from the IC will be about the same length regardless of which type of FMIC you choose. And even if there is a difference it will be precious little, like maybe 300mm more or less.
Keep in mind - you're talking about response here, which has nothing to do with the pros and cons of return flows or straight thru' cores (which are about maximum power capacity).
The only way you'd notice any difference is if you substantially upsized the pipework and possibly fitted a huge IC with massive internal volume.
Hello
So a regular fmic would be better than a return flow fmic?
Ok maybe a ffp I will buy.
Right now I am running a rb25 turbo on my rb20 but will buy a bigger turbo soon because the rb25 turbo is about dead.
Yoshii, you're overthinking this shit again.
1) FFP are generally a complete waste of time. They offer little benefit in their own right and are only really useful for solving packaging problems brought on by shovelling too much other stuff into the engine bay.
2) Return flow coolers are fine up to more than the power you're ever likely to make.
Ok so which type doesn't matter than. I will choose the one which matches my power output.
Return flows will do 300+ rwkw so you got a long way to go yet!!! I have a Blitz return flow and its fine.
I would have to get the Blitz. The one I have now(return flow fmic) is only 400x260x70 in size.
I am about to get a bigger turbo soon.
All depends on your turbo size and power goals!!! If you already have a front mount then buy a turbo to suit its capability.....unless you are considering a complete upgrade then sell sell sell and buy buy buy..............lol.
My turbo is on its way out.
I am upgrading to a bigger one or a high flow.
Aiming for 350hp
Not trying to go off topic here but have simple question, will the blitz return flow be likely to pump out 340kw with ease on a RB3025 with E85? i have option to go blitz or the cheap china one which i already know will do the job but will require much labor to put on...compared to leaving blitz on the car already..
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
