Hello
My rb25 turbo on my rb20det is about gone.
I am looking for a new turbo.
I learned abit more about turbos and things now.
Whatever turbo I buy will be transferrerd over to a rb25 engine if I decide to buy one later this year.
I am looking at a TD05 18g, Hi Flow rb25 turbo(Hyper Gear), a GTX2860R, GTX2863R, GTX2867R, or a GTX 3071R.
I want 400hp but I want to learn how to drive on a car with over 300 first since I have never drive on that goes over 300hp. Don't want any more used rb25 turbos.
My set up now is cool and I have learned how to drive on it, I pushed it to its limits and its old so now its making that death winding sound.
Set up now is the rb25 with a tune which is tuned for boost up, intake pod, and the bigger turbo, fuel, etc.. My boost is set at .9 bar. I have full exhaust from the turbo back with a sports cat. 3" to 5" full exhaust. I am running a gtr pump which is going too, showing signs of dying. Buying a tomei, or walbaro pump within the week. I am running stock injectors. Plan is to get 440cc or 550cc injectors, new turbo, new fuel pump and tune. Not looking for more than 350hp for now until I learn how to drive the car with that much horse power.
Want good response of course.
I have read thru many of the results posted by people with different turbos but there is not much on the ones I mentioned above except for the hi flow rb25 turbo. The results from that seems that the turbo does really get moving until after 3000 rpm almost 4000 on the rb20.
Which of those turbos listed above would be good to have and still a good one to put onto a rb25?
Are there any that I am missing that might be good/
Edited by yoshiii335
Nothing that will be good on an RB25 will feel good on a 20. Lag on the 20 where it will boost fine on the 25. Or, boost fine on the 20 and then choke the 25.
Be prepared to buy a different turbo for the 25. That simple.
Ok.
So which one of the turbos for the 20 is good?
might get away with the 3071, but need a smaller exhaust housing for the 20 and then upgrade with larger for the 25??
but tbh the hi flow is a good option, bit cheaper and when u go 25 u will be able to sell it and hi flow another one suited to a 25
sell rb20, buy rb25 slap a hypergear turbo on and win :)
but from your given choice.. best bet would be the hi flowed u21 from hypergear.. gives the best response and decent power on the 25, theoretticly would suit your 20 better? so that would be my pick plus you can sell it once your done with it since everyone is always after hi flows for the basic upgrade
The results I have seen of people using the high flow 25 on a 20 doesn't look so impressive, most of the power seems to come on in the later rpm range.
My turbo now is on its way out, used to make a whirling noise when winding up but now it makes a more low growling type sound and is super quiet compared to before. The turbo is old and it has been thru three cars so its probably time.
I caned the car this weekend, as I learned about this slang today. I am already having problems with my car's fuel pump and other things from the caning I did this weekend so things to change
it performs mental on a SR20DET non-VCT
so I can assume a RB20 will perform a little worse but still ok..
Let's get real, you want less lag and decent power? then a RB20 is not the answer.... even a B18C Honda motor with a turbo strapped to it makes more torque, more power, and provides better low down than a RB20.
And let's also be honest. This line of questioning has gone on for many months now. Surely you have saved up enough money to just do the whole RB25 + gearbox + diff + suspension + brakes + intercooler + turbo + ECU + tune + rear-vision-mirror-air-freshener upgrades you've been talking about.
Not yet, done some not saved for all
Not sure about the technical side but i reckon RB30 motor and RB25head would be cheaper than buying the whole RB25... it really is pretty simple to do then i agree with the sutututu guy above lol...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
