Recently we put together a 25/30 with a neo de head inc valve springs (bad idea) and wanted to see what the general limitations of standard turbo ones are. This engine was a budget build (though it was done pretty well) but im still a Uni student and on a budget with higher ambitions.
This is generally just me asking for experience with 25's not 30's. Trying to just use it as a rough outline from unopened DET neo's :)
EDIT: Here's a pic of where it starts valve floating. We backed off the boost and touched up the tune a little bit more and managed to make 280 and 550nm but this photo best represents where it dies off.
Big thanks to Rob at Weltmeister Eastside for Dyno tuning (And can definitely recommend him!)
Thanks!
Edited by Pr0x1mity
https://www.sau.com.au/forums/topic/464178-rb25det-neo-valve-spring-limits/
Is there/was there definitely valve float? The reason I ask is that that graph show no signs of it directly. Just a sudden stop to proceedings. Granted the sudden stop does appear to be early, and at a lowish power level for a 30.
How much boost was that? What revs is the stop at?
Power expectation should probably be a bit lower given the smaller ports (they are smaller, aren't they?) and the valve springs are certainly going to flop about with some boost behind them.
If it is/was valve float, then you know what you have to do.
There was another dyno sheet where it looped around with definitely valve float characteristics! Ill try find it.
Running 20psi on a DE head. It's been ported out to DET intake specs and exhaust has been ported out to take full advantage of the manifold.
The turbo still has a bit more boost left in it too!
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
