Hi everyone
About to replace spark plugs on R34 GTR.
Car is pretty much stock so was just looking to replace with the stock plugs (I.e. NGK PFR6A-11) but also came across Bosch (8153-6).
Anyone here ever run the Bosch 8153-6 plugs as they are about half the cost of the NGK's?
Thanks
https://www.sau.com.au/forums/topic/464181-spark-plugs-r34-gtr/
If they are listed as a direct replacement then they will be fine. Should be a reference chart on the web somewhere that will tell you.
Yep, try this one:
http://www.angelfire.com/extreme4/skidoolympique/SPARK_PLUG_CROSS_REFERENCE.htm
Says Bosch equivalent is FR8DCX
See line 1257
That's all that's in mine Chris, I plan to just swap them out every service or 2 given how cheap and easy to get they are.
No misfire issues with spitfires and those plugs at 330or so rwkw.
For a street car they'll be fine.
Yep, try this one:
See line 1257
Strange it comes up with FR8DCX. This was the Bosch catalogue page at Supercheap Auto. post-91000-14605255392572_thumb.jpgpost-91000-14605255571854_thumb.jpg
The package for 8153-6 also shows FR6KPP33X+
Not interested in going copper plugs but thanks.
For me it's coppers every time.
I bought mine from here, about $3.00 a shot. Add some filters to the order to reach $50 and it's free delivery.
https://www.sparesbox.com.au/spark-plugs-ignition
But whatever plug you choose, check the protrusion from the head. Give the spring in the coil pack a bit of a tug to make sure it contacts the conductor.
ISO dimension plugs are a bit shorter than "normal".
Hmmm sounds like the coppers are the way to go. Maybe I'll be a convert. Just out of interest, should I just stick with the stock plug gap of 1.1 and heat range of 6? Car is fairly stock with cat back, boost restrictor removed (running 1 bar) and arc induction box.
I was using 7's but fouled a set after only a few k. Probably due to letting the car idle too long with the ac on during the summer. I've recently been running 6's and changing to 7's when tracking. I'll go back to 7's and see what happens. CBF changing plugs all the time.
