I'm almost done with my 2.75L stroker single-tubo build. I am planning on breaking in and tuning the initial setup with 3" mandrel exhaust (I had a lot of the stuff already and NONE for 3.5"), and the factory FMIC. I'm pretty sure I'll be past the 500 whp mark on pump gas and will be running before and after IAT sensors in the intercooler just to check to see how it handles the boost / temps of the EFR 8374 turbo. My setup is based around response and for now will be limited to pumpgas and only 21 psi boost. I am thinking that the stock FMIC will keep up with this demand with such an efficient turbo especially plumbed in single (ie - less radiant and conductive heat on piping, etc).
That being said, I will need an upgrade because this turbo is capable of 750-800 HP later at higher boost. What is available to BOLT IN and fit up in the factory location for piping and which is the best for the money? I'm in the USA.
Patrick
I have this one http://www.arc-brazing.co.jp/intercooler.html (M079) runs at Suzuka 2 hours nonstop (well once to refuel) and it keeps IAT perfect.
The 100mm ones may take away from response a tiny bit, probably overkill. I removed a Trust 100mm drag IC and response improved and temps were the same. HKS make good ones too.
I am in the middle of fitting a 8374IWG like you from 5s on a 2.8 stroker and it should be easily adequate.
:cheers:
Edited by Meathead
I have this one http://www.arc-brazing.co.jp/intercooler.html (M073) runs at Suzuka 2 hours nonstop (well once to refuel) and it keeps IAT perfect.
The thicker one 100mm may take away from response a tiny bit, probably overkill. HKS make good ones to.
:cheers:
It baffles me why ARC don't make the M109 anymore for the 32-34 GTR's.
  • Like 1
Thought they had gone bust...
OK I see they have been resurrected:
http://www.ft86club.com/forums/showthread.php?p=1487145
as much as I like PWR radiators and oil coolers (I use their radiator).. I'm not a fan of their Intercoolers.. just look at those end tanks.... basic bro science says it doesn't flow that well in terms of efficiently/equally
My untrained and non qualified eye agrees with you. I'm interested what GTSboy has to say.
The GTR coolers they do are probably not terrible. At least the tanks are relatively large and have some shape. They probably look a lot worse than they really are.
The top and bottom tank cooler for R32-3 GTSt is just yucky. Those are a bad idea at any time, let alone when not executed well. Will not bang.
The return flow thingo for R34 GTT is possibly worse. Whilst the return flow idea is better than the top-bottom idea of the R32-3.....the execution is just ridiculously amateurish. Just horrible. The driver's side tank is an abomination of epic proportions
Having said that....I had to build (get built) a new intercooler for my car after the original truck cored one (built last century) was destroyed by an elderly Greek f**ker in an EB Falcon. I got a PWR core. The cores are good. I just got the (return flow) tanks made locally to the same basic pattern as my original.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
    • There's another sensor that sits inside the evaporator, that's a C U N T to get to, but can be done without removing the entire unit. Usually it's not the sensor that dies but the actual capacitor in the circuit (part of the plug that dies).
    • Putting the climate control CU into diagnostic mode is independent of the ECU. You just have to do the dance prescribed in the manual. No, I do not know what the dance is. I have an R32, so use the dance in the R32 manual. On older cars, I would have said "no, the ECU should not affect whether the A/C works".... but for an R34 that might be wrong. I don't recall the detail, but there was extra mods required to make my R32 A/C work against the R34 ECU. The R34 ECU apparently gets involved in the running of the A/C more than earlier cars did. Theoretically, if the PFC is a true plug in, then it should just work the way that the original ECU does - wrt A/C. But there's always scope for them to have not cared. Nope. Pressure switch out = getting the fridgey out to pump the gas out before pulling the switch. The switch really cannot sense gas pressure unless it is up against the gas.
    • Hi guys, thanks for the replies.  I will have to wait till summer to test properly, but it short cycles both when heating and cooling. I’ve ordered a new internal temp sensor that sits under the vent in the steering wheel also, GTSBOY, I have an Apexi FC ecu, I’m assuming I won’t be able to diagnose or would it still work? Could the ecu be causing the problem??   the pressure switch is quite cheap I will get a new one and try it out, hopefully it doesn’t require purging the refrigerant again?
