My first run not modded was around 15 something
Got it down to 14.98 in the same session
The time I went with exhaust, pod filter and stock boost did high 14's couple of low 15's
Last time best was 14.18 with bald tyres, it will be in the 13's next time :P
If a stock skyline can't break 15.5 it would be because of the driver .... not the car
Someone claims to know "lots" of 32/33's that cant break 15.5 down the quarter.... wtf ..??
:P
Hrm.. That's 1, 2, 3 .. Three people who all did 15's in a skyline..
He's taking a dig at me because I said yesterday that I knew "lots" of people who had done 15's in a skyline. Maybe I exagerated a bit, but theres three people on this forum who have just said they ran 15's stock.
haha not just wheelspin with the rockhard tyres... also got to give credit to grandma gear shift speed..and NFI what I'm doing :)
2.884 60ft actually.. :P even my 18.6s 1/4mile golf does faster 60ft than that :(
however at end of that night the time improved to 13.6@112mph :thankyou: (toilet break helps I guess :) )
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
