BEWARE.
USED THIS STUFF ON A CAMRY, (as per instructions) TOOK 4HRS, NEW BATTERY AND MOBILE MECHANIC TO GET STARTED, AFTER WARM UP CAR CHOKES AND DIES UPON ACCELERATION OR UNDER LOAD THEN HAS TROUBLE STARTING AGAIN, CAN'T WORK IT OUT.
ANY TIPS BESIDES PETROL AND A MATCH WOULD BE APPRECIATED, THANKS.
https://www.sau.com.au/forums/topic/464200-foaming-air-intake-cleaner/
I used Subaru upper engine cleaner in my Skyline a few times, it is hard to start if you dump too much into the engine at a time but it clears after running the car for a minute or so. Neighbours love the smoke show
As above, more information is needed or at the very least a better mechanic
Those cans just seem like an expensive way to make smoke. I know Subaru mechanics use them, but Subaru is the one selling them also. Seems like a better idea to not pump so much shit into the intake like exhaust gas recirc and oil vapour.
Nulon foaming air intake cleaner.
Followed exact instructions, well up to the first point of starting the engine. Have been told there could be deposits still in the system so take it for a thrash but if that is the case why does it run ok cold then when the engine warms up it chokes up under load.
What were you cleaning?
Shake the can before use, warm up the engine to normal operating temperature and for best results follow through each of the following steps.
1) Throttle plate cleaning:
Turn off engine and disconnect air intake duct from throttle body. Spray sparingly onto the throttle plate, wipe throttle body gently to remove excess liquid. Reconnect the air intake duct to the throttle body.
2) Inlet manifold cleaning:
Disconnect a vacuum hose from the inlet manifold and start the engine. With the engine running at fast idle, spray approximately half of the can through the vacuum line using the spray tube supplied. Then turn OFF the engine and leave to soak for 5 minutes.
If spark plugs are difficult to remove proceed to Step 4:
3) Piston crown cleaning:
While the engine is still turned off, remove all spark plugs. Spray a 2 second burst into each spark plug hole. Leave the engine to stand for 5 minutes. NOTE: Before reinstalling the spark plugs, cover up the spark plug holes with clean unused paper or cloth and crank the engine several times. Reinstall spark plugs.
4) Final cleaning:
Start the engine and disconnect a vacuum hose from the inlet manifold before spraying the rest of the can into the vacuum line while revving the engine. Reinstall the vacuum line and keep the engine running at fast idle until all the remaining cleaner is purged from the exhaust system.
This treatment is recommended for every scheduled service.
    • bump. Anyone had this done? either 49 or 50mm? Been pondering what to do while mines in storage. Been thinking of DBW but if I do that, then might as well do this too. Want to retain 6 throttles. I have a fully build head(CNC, OS valves, 286/278 cams, etc etc still running squish), and a Greddy old school intake with port matching. Head bench flowed 300cfm. Wondering whether bigger throttles will give me any gains. Makes 563kw.
    • If anyone has any suggestions for a 300-350mm long (or thereabouts) muffler that is 3inch in and out I'm listening
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
