I used that stuff once, didn't do it any good so wouldn't recommend it, same as the fuel injector cleaner you put in your petrol, it ends up in your oil and kills that quicker.
How does fuel injector cleaner end up in your oil?
How I cleaned my air intake..... Removed manifold, Sprayed 2 cans of oven cleaner through all the runners into the plenum...all over throttle body etc...Allow to sit for 30 mins...blast off with Gerni. Removes every bit of gunk.
Nulon foaming air intake cleaner.
Followed exact instructions, well until I stopped following the instructions .
This how I read this...
As to why your car seems to run fine cold but not so good when warm / under load, sounds like an electrical and/or sensor problem to me. See if you can hook up an ECU scanner onto it and see if it throws any error codes
