The way the E85 gets chewed up on spirited drives, a drum , 200 odd Lt ( 3.5 tanks ish) would not last much longer than 2 to 6 months if you drive it 3 times a month. Depends on what you call going for a drive is. Either way I doubt you would have a condensation problem.
Just have to wonder when you buy it from the station how old it is before you buy it ?
I was worried about the E85 I bought before I had to put my car in for some work and had it for over 8 months in 20Lt containers , tipped it in and off it went, just have to love those flex fuel sensors :)
"If" I used E85 all of the time 200lt would not last much more than a month or 2 at the most. But it is good to use 98 pump , then run it close to empty and when the 85 goes in you can get the full benefit of the difference :)
If I did not DRIVE the car, I would not even buy E85, it is a pain getting it where I live but it is so much better than 98, see Paul, you win :)
My car is a weekend only 2-3 times driven a month.
I bought some ethanol treatment for condensation so I'm more worried about the safety of transporting a drum full on its side in the back of the Territory.
I also bought and e85 tester so I'll be able to at least see what the content is.
I wasn't planning on removing the drum from the car, the bung is pretty serious so I can't see it leaking when the drum is next to new, it also can't be filled up past the bung anyway when on its side.
When filling jerry cans, its always recommended to put them on the ground, (due to static elec i think) So filling the drum, thats in the back of you're car, nope, would not do. Plus, as above, Its illegal.
Local servo actually has still shots of its camera's of some bloke filling a jerry in the back of his ute, and it catches alight, scary stuff!
From a quick google search, the total fuel you're allowed to carry with a car is 250l, including car's fuel tank, and It has to be mounted outside the car.
http://www.whatsupdownunder.com.au/News/Tips-Hints/Carrying-Extra-Fuel/Jerry-Cans-February-2015
No idea how accurate this is though.
This is funny, mainly because Ethanol/Methanol is the treatment for most moisture issues. There is no way moisture will ever be a problem in a sealed container, and even if by some chance you managed to pour a cup of water into the drum, or left the lid off in a rain storm, the ethanol would quickly absorb the moisture and get rid of it from your tank, rather than letting it sit and rust. That amount of water evenly distributed in the tank would barely change the tune, I doubt an AFR gauge would read the difference.
I have used 2 year old United fuel from a customers car, he was too worried to run it and wanted me to drain the tank for fresh fuel to tune with. I poured it straight into the Evo running 32psi, no issues. AFR's perfect, ethanol percentage within 1% of what they were originally. If you tried that with 98 you wouldn't get far, hence why I am so amused when this discussion pops up each few months.
I've been running straight e85 for over 7 years now, never changed back, never touched my fuel system, never used stabilisers either. The only down side I have noticed is less K's to a tank. Any other ethanol myth is generally false. I prefer not to run the ethanol content sensor at this stage because as GTSboy mentioned they can lead you up the garden path, and it's another sensor to fail affecting the tune.
Dan, if you need it I have my old E85 205L oil drum I never use anymore, it has a servo hose and nozzle fitted. If you are interested I can send a pic. I just use 20L's these days, but I have 4 United servos selling e85 within 5 K's now.
I'm on the phone with RTA as we speak rather than working of google searches, which I've also been doing :)
I've also seen the stuff about static, you simply need to earth yourself, the drum/nozzle etc. I'm also not going to be wearing synthetic clothing or holding my phone.
For $20, happy to throw it in, not a big deal.
Would be interested to see that drum. I've got a drum but your nozzle setup sounds interesting.
Just got off the phone.
I can LEGALLY have a FULL drum IN the car. Any more than a drum and it must be trailered, placarded with dangersou goods signage and you need a license but a single drum is LEGAL
Must be secured and he advised me about the risks of ignition and fuel vapors.
Windows will be down, will drive slower than usual, will employ ratchet straps.
This information is specific to NSW, I have no idea about other states.
The issue becomes if the service station will allow me to fill it in the back of the car, given once full I would not be able to lift it by myself.
Earthing shouldn't be an issue as I can just use an earthing lead from the drum to an earthing point in the car/to the pump.
Alternatively I may need to just borrow a bunch of jerry cans from my mates and fill those instead.
Edited by ActionDan
I got pulled up for filling a plastic Jerry in the back of ute. Two chances filling up a 44 in an SUV.
Interesting, I regularly fill up 4x jerry cans and my R33 shit box and no one has ever stopped me though?
Heavy vehicles have 1000+ litres in multiple tanks, including belly tanks under trailers with no placards etc. Also a lot of Earth moving companies use portable storage tanks in Utes without problems
as a earthmover that has a big arse truck I will say this is incorrect, my truck has only one 400l tank and it does have a placard and so does the excavator which is only 110l
Also contrary to popular belief diesel in not flammable, it is a combustible liquid so the same rules may not apply
Edit: if your desiel is flammable stop buying from that servo
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
