can i have your old injectors fpr and fuel rail pretty please
If I ever get rid of them.
If my stock fuel pressure regulator will support 440cc or 550cc injectors and allow me to get the full use out of them, of course I will keep the stock set up, but I did research and from what I found, it is recommended to upgrade the fuel pressure regulator.
So please anyone, if I don't need to change it, just let me know.
See. There's the problem. I bolded the problem. It's just absolutely not true. And if you did your research properly, you would have found very specific mentions, by me and others, on this very site, saying that you do not. Do you want me to do the search for you? Take me 30 seconds. Watch.
  • Like 1
I am asking one thing,
If you do not want to help please stay off of my post.
You are a hindrance.
I have learned much more about cars in the past time.
I have read many posts saying that the stock fuel pressure regulator is fine with 550 injectors and its about setting the mix and etc. Also I read that it is not good and that a FPR is needed.
I have read many articles and posts.
So I read many other forums other than SAU. Your country is not the only other country outside of Japan that has had rb's and skyline's for years. Even in the states they have been there.
So you can post all the links you want, if you want to help, good, thank you, if not please go away.
The internet has millions of pages of information, I am not going to find everything.
It seems many people have different thoughts on what needs to be done.
So I will read more and go from there.
If you really want to have a childish row, please take it and go else where.
No time to waste, got to keep moving.
If you want to help, I am listening.
I will check out my FPR I have now. Dont know if its running properly or not.
With me doing the hard run I did and my fuel pump starting to go out, there may be other parts of my car that needs to be fixed, replaced.
I will get one if needed.
http://www.tomeiusa.com/_2003web-catalogue/e135_fuel_regulator.html
Based on Tomei, they say it should be used.
They have an interest in you buying one don't they...
You don't need one. If your stock one is broken buy a new stock one.
End of thread.
Dose pipe ftw.
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
