What Are My Options - My Front R33 Gtr Indicator Enclosure Fell Loose And Is Damaged?
Hey guys, so frustrating - I just got my front bar nicely painted and as drove out of the workshop one of my front indicator enclosures on my GTR Front bar fell loose and broke.
It's ridiculous how these things are so rare and they're worth nearly $600 to replace (including the clear globe housing). So does anyone here know where I can get a new pair more cheaper or even better know where I can buy just one?
I live in the western suburbs of Melbourne. Please help...I'm so frustrated.
Many thanks in advance.
Cheers
Hey guys, appreciate all your help.
It's those black indicator backing enclosures housing the indicators...one broke but all good - I managed to pick up a pair of Kudos Motorsports for around $80.00 shipped. Hopefully they will fit flush.
Whilst I'm at it - any tips on cleaning those lights? Mine is a bit like the one White GTR in the photo - it's not too bad but a bit Yellowy.
Many thanks.
Drive back into the shop and have them replace it as they did not assemble it correctly?
The guys at the workshop that did the work are great and are happy to wear the cost of getting a replacement so all good.
Many thanks.
That's not a GTR
Get some Glassylite or a plastic polish...or toothpaste and paper towels will fix it.
That's not a GTR
Yeah a closer look does show that White one is not a GTR.
Anyway, so Toothpaste with paper towels. Any particular technique to cleaning or do I just put it on and then wipe it off?
Like cleaning your teeth - pretend the lights are teeth
Wet the lights with some water first, put fair amounts of toothpaste on paper towel and polish away with it. Rinse with water after / wipe with damp sponge. Takes a fair bit of elbow grease the polishing, depending on how oxidised they are, but you'll see the difference straight away.
This is a temp solution...will stay clear for a month or so at most before it comes back. Using protective UV sealants after polishing can get you more time between polishes.
Thanks Bird - great tips. Much appreciated. I'll give it a shot tomorrow morning. :yes:
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
