Got a squeaky clutch after the car was on stands for 2 months and pin pointed the noise to the clutch fork. R34 gtt.
I'm assuming it's the pivot point as I had the same issue in My old r33 which I greased up with bike chain oil and it was fine after that. This one seems to look a bit more tricky though since it has 2 points that pivot rather than one.
Anyone had luck greasing a pull type with the box on the car? I really don't want to take it off for something so small as the clutch is still new on it and nothing needs replacing.
Open to any suggestions!
Cheers
https://www.sau.com.au/forums/topic/464237-greasing-pull-type-clutch-fork/
It was fine for so long then decided it wanted to squeak just because it sat around not being used haha :(
I'll try to get a rubber tube so I can curve it over the fork to get the other side with some grease.
Just scared of getting it on the pressure plate is all!
Thanks mate
