I've always been a massive fan of the mighty t51r :)
What are your plans with wheels? U gonna fit some big rubber? I think u will need it
Looking at some 18x10.5 +12 Gramlights... But also looking at another set.. A bit undecided at the moment.
5 hours ago, jmknights93 said:
Looks like you had fun.
Definitely did.. The 2 more runs I did after that video were much faster and on edge... Next time I go out i'll have coilovers and all other supporting suspension work so it won't feel so high and boaty lol
  • Like 1
  • 1 month later...
So there has been a few acquisitions in the past couple of months... Picked up a Nismo Coppermix Twin plate Comp spec from Ants, which is getting put in on Monday
And this lovely set of boxes arrived today after waiting 4 weeks..
Ordered the track day essentials starting with a Trust 13 row oil cooler/relocator kit with all the lines and air diversion plate etc
And the box I was waiting 4 weeks for....
Aragosta Type-S Rubber mount coilovers, 7kg front / 5kg rear
Also picked up some Driftworks adjustable arms
Rear traction rods
Front tension rods
Front Camber arms
Rear camber arms
Edited by GRKGTR
  • Like 1
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
